NETGEAR M4300-12X12F Managed Switch
Quicklinx: C4Z9WS00 Mfr#: XSM4324S-100NES
Type: 10 Gigabit Ethernet
Ports: 24
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£2,777.01 ex VAT
£3,332.41 inc VAT
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architectures provide advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-12X12F comes with 12 ports 10GBASE-T and 12 ports 10GBASE-X SFP+ in a half-width form factor. All 24 ports are independent and 1G backward compatible for progressive transition to 10G speeds. Ideal for server and storage aggregation: two half-width M4300 switches can be installed in a single rack space. M4300-12X12F is line-rate with 480Gbps fabric for SMB core applications as well as spine and leaf stacking architectures.
  • Robust security
    Equipped with RADIUS and TACACS+ authentication methods, the NETGEAR M4300-12X12F ensures secure network access control, offering peace of mind for network administrators.
  • High performance
    With a switching capacity of 480 Gbps, this switch is designed to handle the demands of large data transfers and high-speed connectivity, ensuring efficient network performance.
  • Advanced networking
    Supporting a wide range of Layer 3 switching features such as ARP support, Access Control List (ACL) support, and Quality of Service (QoS), the M4300-12X12F is capable of sophisticated network management and prioritization.
  • Versatile connectivity
    Featuring 24 ports, including 12 10GBase-T and 12 10GBase-X SFP+ ports, this switch offers flexible connection options for a variety of network devices and cable types.
  • Efficient management
    Manageable via CLI, HTTPS, SNMP, SSH, and Telnet, the M4300-12X12F allows for easy and versatile management, catering to a wide range of administrative preferences.
NETGEAR M4300-12X12F - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
12 x 10/100/1000/10000 + 12 x 10 Gigabit SFP+
Performance
Switching capacity: 480 Gbps
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
12 x 10GBase-T RJ-45 , 12 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
Internal power supply
AC 120/230 V
Europe, Americas
Limited warranty - lifetime
C4Z9 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £13.93
Ports: 24
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
