The NETGEAR ProSAFE M4200-10MG-PoE+ Managed Switch was designed from the ground up to optimize the installation of Wave 2 11ac access points. Includes eight full power PoE+ and multi-speed 1G, 2.5G ports for 100 meter cable runs, combined with two 10G uplinks for a fully non-blocking deployment of eight Wave 2 11ac access points. NETGEAR Multigigabit Ethernet is compatible with most major wireless and switching vendors managed solutions, and the only one with 8x2.5G to the AP and 2x10G line-rate aggregation to the wiring closet. Plenum rated, slim design and mounting accessories allow for access point placement optimization and cabling efficiency.
Robust performance
With a switching capacity of 90 Gbps and throughput of 66.9 Mpps, the NETGEAR M4200 Intelligent Edge Series ensures efficient data handling for high-demand networks. -
Versatile connectivity
Equipped with a variety of ports including 1/2.5G (PoE+) and 10GBase-X SFP+ ports, this switch offers flexible connection options for a wide range of devices. -
Advanced management
Support for CLI, HTTPS, RMON, SNMP, SSH, and Telnet allows for comprehensive remote management, ensuring easy setup and ongoing maintenance. -
Comprehensive PoE+ support
With a PoE budget of 240 W, the GSM4210P can power multiple devices, including surveillance cameras and VoIP phones, through its Ethernet cables, simplifying the network infrastructure. -
Layer 3 switching capability
Layer 3 advanced switching provides enhanced network efficiency and security, supporting static IPv4 and IPv6 routing, RIP, and MLD for improved traffic management.
- NETGEAR M4200 Intelligent Edge Series GSM4210P - switch - 10 ports - Managed - rack-mountable
- Switch - 10 ports - L3 - Managed
- Enclosure Type
- Side to side airflow rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 6 x 100/1000/2.5G (PoE+) + 2 x 100/1000/2.5G/5G (PoE+) + 2 x 1 Gigabit / 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 240 W
- Performance
- Switching capacity: 90 Gbps , Throughput: 66.9 Mpps
- MAC Address Table Size
- 16K entries
- Routing Protocol
- RIP, static IPv4 routing, static IPv6 routing, MLD
- Remote Management Protocol
- SNMP, RMON, Telnet, HTTPS, SSH, CLI
- DHCP support, VLAN support, IGMP snooping, RSTP support, MLD snooping, 16MB packet buffer
- IEEE 802.3ad (LACP), IEEE 802.1AX
- Power
- AC 120/230 V
- Localisation
- Europe, Americas
- NETGEAR lifetime warranty
- Enclosure Type
- Subtype
- Ports
- PoE+
- PoE Budget
- 240 W
- Performance
- 16K entries
- Routing Protocol
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- Processor
- : 800 MHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 1 x management (Gigabit LAN) 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 , 1 x serial (console) RJ-45 , 1 x console (mini-USB) , 1 x USB , 6 x 1/2.5G (PoE+) RJ-45 , 2 x 1/2.5G/5G (PoE+) RJ-45 , 2 x 10GBase-X SFP+ , 1 x USB Type A
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 286.1 Watt
- Rack Mounting Kit
- Included
- Localisation
- Europe, Americas
- Software Included
- Drivers & Utilities
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.93 |
