NETGEAR M4200-10MG-POE+ Managed Switch
Quicklinx: C4YBWS00 Mfr#: GSM4210P-100NES
Type: 10 Gigabit Ethernet
Ports: 10
Managed: Yes
POE: PoE+
£613.94 ex VAT
£736.72 inc VAT
The NETGEAR ProSAFE M4200-10MG-PoE+ Managed Switch was designed from the ground up to optimize the installation of Wave 2 11ac access points. Includes eight full power PoE+ and multi-speed 1G, 2.5G ports for 100 meter cable runs, combined with two 10G uplinks for a fully non-blocking deployment of eight Wave 2 11ac access points. NETGEAR Multigigabit Ethernet is compatible with most major wireless and switching vendors managed solutions, and the only one with 8x2.5G to the AP and 2x10G line-rate aggregation to the wiring closet. Plenum rated, slim design and mounting accessories allow for access point placement optimization and cabling efficiency.
  • Robust performance
    With a switching capacity of 90 Gbps and throughput of 66.9 Mpps, the NETGEAR M4200 Intelligent Edge Series ensures efficient data handling for high-demand networks.
  • Versatile connectivity
    Equipped with a variety of ports including 1/2.5G (PoE+) and 10GBase-X SFP+ ports, this switch offers flexible connection options for a wide range of devices.
  • Advanced management
    Support for CLI, HTTPS, RMON, SNMP, SSH, and Telnet allows for comprehensive remote management, ensuring easy setup and ongoing maintenance.
  • Comprehensive PoE+ support
    With a PoE budget of 240 W, the GSM4210P can power multiple devices, including surveillance cameras and VoIP phones, through its Ethernet cables, simplifying the network infrastructure.
  • Layer 3 switching capability
    Layer 3 advanced switching provides enhanced network efficiency and security, supporting static IPv4 and IPv6 routing, RIP, and MLD for improved traffic management.
NETGEAR M4200 Intelligent Edge Series GSM4210P - switch - 10 ports - Managed - rack-mountable
Switch - 10 ports - L3 - Managed
Enclosure Type
Side to side airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
6 x 100/1000/2.5G (PoE+) + 2 x 100/1000/2.5G/5G (PoE+) + 2 x 1 Gigabit / 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 90 Gbps , Throughput: 66.9 Mpps
MAC Address Table Size
16K entries
Routing Protocol
RIP, static IPv4 routing, static IPv6 routing, MLD
Remote Management Protocol
SNMP, RMON, Telnet, HTTPS, SSH, CLI
DHCP support, VLAN support, IGMP snooping, RSTP support, MLD snooping, 16MB packet buffer
IEEE 802.3ad (LACP), IEEE 802.1AX
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
PoE+
PoE Budget
240 W
Performance
16K entries
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
: 800 MHz
RAM
1 GB
Flash Memory
256 MB
1 x management (Gigabit LAN) 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 , 1 x serial (console) RJ-45 , 1 x console (mini-USB) , 1 x USB , 6 x 1/2.5G (PoE+) RJ-45 , 2 x 1/2.5G/5G (PoE+) RJ-45 , 2 x 10GBase-X SFP+ , 1 x USB Type A
Internal power supply
AC 120/230 V
286.1 Watt
Rack Mounting Kit
Included
Europe, Americas
Software Included
Drivers & Utilities
C4YB C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
C4YB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
C4YB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.24
Ports: 10
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: £500 - £750
