Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
Robust security
Equipped with RADIUS and TACACS+ authentication methods, alongside Access Control List (ACL) support, this switch ensures secure network access and management, safeguarding against unauthorized access. -
Comprehensive connectivity
Featuring 12 1000Base-T ports and 2 shared SFP ports, the NETGEAR M4100-D12G provides versatile connectivity options for a wide range of devices, supporting efficient data transfer and reliable connections. -
Efficient network management
Manageable via CLI, HTTPS, SNMP, and more, this switch offers comprehensive remote management capabilities, allowing for efficient monitoring and control of network resources. -
Advanced networking features
With support for Layer 2+ switching, VLAN, LACP, and static IPv4 routing, the switch facilitates sophisticated network configurations and efficient traffic management, enhancing network performance. -
Energy-efficient design
The fanless design not only ensures silent operation but also reduces energy consumption, making the NETGEAR M4100-D12G an eco-friendly choice for any networking environment.
- NETGEAR M4100-D12G - switch - 12 ports - Managed
- Switch - 12 ports - L2+ - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 12 x 10/100/1000 + 2 x shared SFP
- Performance
- Bandwidth: 24 Gbps
- MAC Address Table Size
- 16K entries
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI
- Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, RADIUS support, MLD snooping, IPv4 support, fanless, LACP support, DHCP client, MVR, CoS
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 32.8 cm x 16.9 cm x 4.32 cm
- 1.33 kg
- Localisation
- Canada, United States, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 16K entries
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Status Indicators
- Port status, power
- 1 x 1000Base-T RJ-45 , 11 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B
- Power Device
- External power adapter
- Voltage Required
- 18.8 watt
- Cables Included
- 1 x USB cable
- CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A
- Localisation
- Software Included
- Drivers & Utilities
- 32.8 cm
- 16.9 cm
- 4.32 cm
- 1.33 kg
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.05 |
