NetGear M4100-D12G Managed Switch
Quicklinx: 8TYZWS00 Mfr#: GSM5212-100NES
Type: Gigabit Ethernet
Ports: 12
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£159.52 ex VAT
£191.42 inc VAT
Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
  • Robust security
    Equipped with RADIUS and TACACS+ authentication methods, alongside Access Control List (ACL) support, this switch ensures secure network access and management, safeguarding against unauthorized access.
  • Comprehensive connectivity
    Featuring 12 1000Base-T ports and 2 shared SFP ports, the NETGEAR M4100-D12G provides versatile connectivity options for a wide range of devices, supporting efficient data transfer and reliable connections.
  • Efficient network management
    Manageable via CLI, HTTPS, SNMP, and more, this switch offers comprehensive remote management capabilities, allowing for efficient monitoring and control of network resources.
  • Advanced networking features
    With support for Layer 2+ switching, VLAN, LACP, and static IPv4 routing, the switch facilitates sophisticated network configurations and efficient traffic management, enhancing network performance.
  • Energy-efficient design
    The fanless design not only ensures silent operation but also reduces energy consumption, making the NETGEAR M4100-D12G an eco-friendly choice for any networking environment.
NETGEAR M4100-D12G - switch - 12 ports - Managed
Switch - 12 ports - L2+ - Managed
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 + 2 x shared SFP
Performance
Bandwidth: 24 Gbps
MAC Address Table Size
16K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, RADIUS support, MLD snooping, IPv4 support, fanless, LACP support, DHCP client, MVR, CoS
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3az
32.8 cm x 16.9 cm x 4.32 cm
1.33 kg
Canada, United States, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 24 Gbps
16K entries
Routing Protocol
Static IPv4 routing
Authentication Method
RADIUS, TACACS+
Status Indicators
Port status, power
1 x 1000Base-T RJ-45 , 11 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B
External power adapter
18.8 watt
1 x USB cable
CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A
Software Included
Drivers & Utilities
32.8 cm
16.9 cm
4.32 cm
1.33 kg
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
8TYZ C2G 2m USB 2.0 A/B Cable - Black In Stock £4.05
Ports: 12
Managed: Yes
POE: No
Brand: NETGEAR
