Netgear M4100-50G-PoE+ Managed Switch
Quicklinx: 8M60WS00 Mfr#: GSM7248P-100NES
Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
  • Robust security
    Equipped with RADIUS and TACACS+ authentication methods, this switch ensures secure network access control, providing peace of mind for sensitive data transmission.
  • Comprehensive networking capabilities
    Featuring advanced Layer 2+ switching, VLAN support, and static IPv4 routing, the NETGEAR M4100-50G-PoE+ facilitates efficient network segmentation and routing for optimized performance.
  • Efficient power management
    With a generous PoE budget of 380 W and support for PoE+, the switch efficiently powers multiple devices over the network, reducing cable clutter and energy costs.
  • High-capacity networking
    A 100 Gbps bandwidth and a MAC Address Table Size of 16K entries enable the handling of extensive data traffic, ensuring smooth and reliable network performance.
  • Flexible installation options
    The NETGEAR M4100-50G-PoE+ can be deployed in a desktop or rack-mounted setup, providing versatility to fit various spatial configurations and networking requirements.
NETGEAR M4100-50G-PoE+ - switch - 50 ports - Managed - rack-mountable
Switch - 50 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
50 x 10/100/1000 + 4 x shared SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
380 W
Performance
Bandwidth: 100 Gbps
16K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, RADIUS support, MLD snooping, IPv4 support, LACP support, DHCP client, MVR, CoS
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
44 cm x 31 cm x 4.32 cm
4.96 kg
Canada, United States, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
380 W
Performance
Bandwidth: 100 Gbps
16K entries
Routing Protocol
Static IPv4 routing
Authentication Method
RADIUS, TACACS+
Status Indicators
Port status, power, RPS (Redundant Power Supply), PoE, fan
48 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B
Internal power supply
555.5 watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A
Software Included
Drivers & Utilities
44 cm
31 cm
4.32 cm
4.96 kg
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
8M60 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.03
