NETGEAR LTE Bridge 2 Port Fail Over
Quicklinx: DBNJWS00 Mfr#: LB2120-100UKS
The NETGEAR LTE Modem LB2120 gives you a simple, fail-safe connectivity solution for your devices or services, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect your existing wire line broadband connection to this modem to provide an automatic 4G LTE or 3G broadband backup connection.
  • Versatile Connectivity
    With both wired and wireless connectivity options, the NETGEAR LB2120 ensures you stay connected. Whether you're looking for a stable wired connection via Gigabit Ethernet or the flexibility of a wireless cellular modem, this device has you covered.
  • High-Speed 4G LTE
    Experience fast Internet speeds with the NETGEAR LB2120's support for 4G LTE. This modem is designed to deliver up to 150 Mbps transfer rates, making it ideal for communication and streaming.
  • Easy Setup
    The NETGEAR LB2120 supports a wide range of operating systems including Apple MacOS X 10.6.8 or later and Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, ensuring an easy setup process across various devices.
  • Enhanced Features
    This modem comes equipped with SMS alert capabilities and supports the TR-069 remote management protocol, offering enhanced security and ease of management for your network.
NETGEAR LB2120 - wireless cellular modem - 4G LTE
Wireless cellular modem - Gigabit Ethernet
External
United Kingdom
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
UMTS, LTE, DC-HSPA+
Digital Ports Qty
2
Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
11.9 cm x 9.91 cm x 3.05 cm
181.4 g
External
United Kingdom
Modem
Bus
Gigabit Ethernet
Wireless, wired
Max Transfer Rate
150 Mbps
UMTS, LTE, DC-HSPA+
Digital Ports Qty
2
Antenna
External detachable and internal
Remote Management Protocol
TR-069
SMS alert
2 x 1000Base-T - RJ-45 , 2 x aerial - TS-9
SIM Card Supported
Micro-SIM x 1
1 x network cable
Limited warranty - lifetime
11.9 cm
9.91 cm
3.05 cm
181.4 g
