NETGEAR LTE Bridge 2 Port Fail Over
Quicklinx: DBNJWS00 Mfr#: LB2120-100UKS
£113.14 ex VAT
£135.76 inc VAT
The NETGEAR LTE Modem LB2120 gives you a simple, fail-safe connectivity solution for your devices or services, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect your existing wire line broadband connection to this modem to provide an automatic 4G LTE or 3G broadband backup connection.
NETGEAR LB2120 - wireless cellular modem - 4G LTE
Wireless cellular modem - Gigabit Ethernet
External
United Kingdom
Max Transfer Rate
150 Mbps
Mobile Communication Protocol
UMTS, LTE, DC-HSPA+
Digital Ports Qty
2
Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
11.9 cm x 9.91 cm x 3.05 cm
181.4 g
External
United Kingdom
Modem
Bus
Gigabit Ethernet
Wireless, wired
Max Transfer Rate
150 Mbps
UMTS, LTE, DC-HSPA+
Digital Ports Qty
2
Antenna
External detachable and internal
Remote Management Protocol
TR-069
SMS alert
2 x 1000Base-T - RJ-45 , 2 x aerial - TS-9
SIM Card Supported
Micro-SIM x 1
1 x network cable
Limited warranty - lifetime
11.9 cm
9.91 cm
3.05 cm
181.4 g
