The NETGEAR LTE Modem LB2120 gives you a simple, fail-safe connectivity solution for your devices or services, avoiding disruptions in broadband when your fixed wire line goes down. Simply connect your existing wire line broadband connection to this modem to provide an automatic 4G LTE or 3G broadband backup connection.
Versatile Connectivity
With both wired and wireless connectivity options, the NETGEAR LB2120 ensures you stay connected. Whether you're looking for a stable wired connection via Gigabit Ethernet or the flexibility of a wireless cellular modem, this device has you covered. -
High-Speed 4G LTE
Experience fast Internet speeds with the NETGEAR LB2120's support for 4G LTE. This modem is designed to deliver up to 150 Mbps transfer rates, making it ideal for communication and streaming. -
Easy Setup
The NETGEAR LB2120 supports a wide range of operating systems including Apple MacOS X 10.6.8 or later and Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, ensuring an easy setup process across various devices. -
Enhanced Features
This modem comes equipped with SMS alert capabilities and supports the TR-069 remote management protocol, offering enhanced security and ease of management for your network.
- NETGEAR LB2120 - wireless cellular modem - 4G LTE
- Wireless cellular modem - Gigabit Ethernet
- Form Factor
- External
- Localisation
- United Kingdom
- Max Transfer Rate
- 150 Mbps
- Mobile Communication Protocol
- UMTS, LTE, DC-HSPA+
- Digital Ports Qty
- 2
- System Requirements
- Apple MacOS X 10.6.8 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- 11.9 cm x 9.91 cm x 3.05 cm
- 181.4 g
- Limited lifetime warranty
- Form Factor
- External
- Localisation
- United Kingdom
Modem
- Bus
- Gigabit Ethernet
- Connectivity Technology
- Wireless, wired
- Max Transfer Rate
- 150 Mbps
- Digital Ports Qty
- 2
- Antenna
- External detachable and internal
- Remote Management Protocol
- TR-069
- SMS alert
- 2 x 1000Base-T - RJ-45 , 2 x aerial - TS-9
- SIM Card Supported
- Micro-SIM x 1
- Cables Included
- 1 x network cable
- OS Required
- Limited warranty - lifetime
- 11.9 cm
- 9.91 cm
- 3.05 cm
- 181.4 g
