The NETGEAR VIZNTM GC510P is the first App Managed Smart Cloud 8-port Gigabit Ethernet PoE+ Switch from NETGEAR with anywhere configuration and management. All you need is the NETGEAR Insight app for easy setup, monitoring and remote/cloud management of your VIZN Switches, VIZN Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR VIZN GC510P features 8 PoE+ copper Gigabit Ethernet ports and 2 SFP Fiber ports with a total budget of 134 W for maximum flexibility and easy deployment in your network. With its remote cloud manageability, sleek design, PoE power and fanless, silent operation, it's the most versatile switch on the market for any environment. Now you can setup, manage and monitor your network all from the palm of your hand and from anywhere in the world!
One-touch management
App managed Smart Cloud Switch using the NETGEAR Insight app for one-touch installation and management of all your GC510P and VIZN Switches and APs, no additional hardware needed. -
Anywhere monitoring & management
Smart Cloud remote management for unrivaled mobile management experience of your wireless network - anywhere, anytime, from the palm of your hand. -
All-inclusive connectivity & PoE+ (802.3at)
8-port PoE+ Gigabit copper (134W) + 2-port Gigabit SFP fiber. -
Smart switching
Advanced L2 switching capabilities (VLANs, LAGs, QoS, ACLs, IPv6 support, IGMP snooping, multicast, RSTP, rate limiting, etc) and advanced per port PoE controls. -
Modern design
Clean, modern design, wall-mountable, rack-mountable and fanless, silent operation for flexible deployment in any environment, even noise sensitive (classrooms, offices, patient care).
- NETGEAR Insight Managed GC510P - switch - 8 ports - smart - rack-mountable
- Switch - 8 ports - L2+ - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 134 W
- Performance
- Fabric throughput: 20 Gbps , 1 Gbps copper latency (64-byte packets): 3000 µs , 1 Gbps fibre latency (64-byte packets): 2400 µs , Forwarding performance (64-byte packet size): 14.9 Mfps , 1 Gbps fibre latency (1518-byte packets): 2140 µs
- Capacity
- ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- HTTP, HTTPS, TFTP
- Flow control, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, fanless, LLDP support, DHCP relay, LACP, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, SPQ, loop prevention, security lock slot (cable lock sold separately), 802.1x authentication, cloud managed, ToS, 1.5MB packet buffer, cable test, administrator's password, PoE management, Link Aggregation, DNS client, protected ports, WRR
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, UPnP
- 31.4 cm x 18.8 cm x 4.4 cm
- 2 kg
- Localisation
- United Kingdom, Europe
- 5-year warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 134 W
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- HTTP, HTTPS, TFTP
- Encryption Algorithm
- MD5, SSL, TLS, PEAP
- Authentication Method
- RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- Processor
- 1 Cortex-A9: 400 MHz
- RAM
- 256 MB
- Flash Memory
- 264 MB
- Status Indicators
- Power, status, PoE, link/activity/speed
- 8 x 10/100/1000 Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- 146.9 Watt
- Included Accessories
- Wall mounting kit, foot pad set
- Rack Mounting Kit
- Included
- MTBF
- 692,457 hours
- BSMI CNS 13438 Class A, UL 60950-1 Second Edition, KCC, GB 9254-2008, K60950-1, RCM, BSMI CNS 14336-1, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, EN 55032:2012+AC:2013 Class A, AS/NZS 60950-1:2015, CISPR 32:2015 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, ICES-003:2016, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- 31.4 cm
- 18.8 cm
- 4.4 cm
- 2 kg
- Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
- 0 °C
- 45 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
