NETGEAR Insight Managed 8-port Gigabit Ethernet High-Power PoE+ Smart Cloud Switch
Quicklinx: D576WS00 Mfr#: GC510PP-100EUS
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
£200.67 ex VAT
£240.80 inc VAT
The NETGEAR VIZNTM GC510PP is the first App Managed Smart Cloud 8-port Gigabit Ethernet High-Power PoE+ Switch from NETGEAR with anywhere configuration and management. All you need is the NETGEAR Insight app for easy setup, monitoring and remote/cloud management of your VIZN Switches, VIZN Wireless Access Points, and Business-class ReadyNAS storage. The NETGEAR VIZN GC510PP features 8 PoE+ copper Gigabit Ethernet ports and 2 SFP Fiber ports with a total budget of 195 W for maximum flexibility and easy deployment in your network. With its remote cloud manageability, sleek design, high PoE power budget and whisper quiet operation, it's the most versatile switch on the market for any environment. Now you can setup, manage and monitor your network all from the palm of your hand and from anywhere in the world!
  • One-touch management
    App managed Smart Cloud Switch using the NETGEAR Insight app for one-touch installation and management of all your GC110P and VIZN Switches and APs, no additional hardware needed.
  • Anywhere monitoring & management
    Smart Cloud remote management for unrivaled mobile management experience of your wireless network - anywhere, anytime, from the palm of your hand.
  • All-inclusive connectivity & PoE+ (802.3at)
    8-port PoE+ Gigabit copper (195 W) + 2-port Gigabit SFP fiber.
  • Smart switching
    Advanced L2 switching capabilities (VLANs, LAGs, QoS, ACLs, IPv6 support, IGMP snooping, multicast, RSTP, rate limiting, etc) and advanced per port PoE controls.
  • Modern design
    Clean, modern design and whisper-quiet operation for flexible deployment in any environment, even noise sensitive (classrooms, offices, patient care).
NETGEAR Insight Managed GC510PP - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - L2+ - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
195 W
Performance
Fabric throughput: 20 Gbps , 1 Gbps copper latency (64-byte packets): 3000 µs , 1 Gbps fibre latency (64-byte packets): 2400 µs , Forwarding performance (64-byte packet size): 14.9 Mfps , 1 Gbps fibre latency (1518-byte packets): 2140 µs
ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
HTTP, HTTPS, TFTP
Flow control, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, LLDP support, DHCP relay, LACP, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, SPQ, loop prevention, security lock slot (cable lock sold separately), 802.1x authentication, cloud managed, ToS, 1.5MB packet buffer, cable test, administrator's password, PoE management, Link Aggregation, DNS client, 1 fan, protected ports, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, UPnP
31.4 cm x 18.8 cm x 4.4 cm
2.23 kg
United Kingdom, Europe
5-year warranty
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
195 W
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
HTTP, HTTPS, TFTP
Encryption Algorithm
MD5, SSL, TLS, PEAP
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
1 Cortex-A9: 400 MHz
RAM
256 MB
Flash Memory
264 MB
Status Indicators
Power, status, PoE, fan, link/activity/speed
8 x 10/100/1000 Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
Internal power supply
200 watt
Wall mounting kit, foot pad set
Rack Mounting Kit
Included
MTBF
381,503 hours
BSMI CNS 13438 Class A, UL 60950-1 Second Edition, KCC, GB 9254-2008, K60950-1, RCM, BSMI CNS 14336-1, IEC 60950-1:2005 Second Edition, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, EN 55032:2012+AC:2013 Class A, AS/NZS 60950-1:2015, CISPR 32:2015 Class A, CAN/CSA-C22.2 No. 60950-1-07 Second Edition, ICES-003:2016, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
31.4 cm
18.8 cm
4.4 cm
2.23 kg
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
45 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Ports: 8
Managed: Yes
POE: PoE+
Brand: NETGEAR
