The NETGEAR Insight VPN router is not only a high-performance router for small- to medium-size businesses, but also offers an SPI firewall.
Easy and secure
The NETGEAR Insight Instant VPN router provides both secure yet easy site-to-site tunnels and secure access for remote clients. -
Flexible operation
You can start with one or two Instant VPN routers and as your business grows and your needs increase, you can add more devices to your VPN groups to have a complete meshed network between locations. -
Business grade
The rugged metal unit houses advanced, high-quality electronics.
- NETGEAR Insight BR500 - router - desktop
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Performance
- VPN throughput: 60 Mbps , LAN-to-WAN throughput: 924 Mbps
- Capacity
- VLANs supported: 4094
- PPTP, L2TP, NTP, PPPoE, DHCP, DNS, DDNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- HTTP, NTP
- NAT support, SPI, IPv6 support, VPN passthrough, firmware upgradable, QoS, DHCP server, DNS proxy, port forwarding, port triggering, DHCP relay, security lock slot (cable lock sold separately), ToS, DoS protection, DMZ support
- IEEE 802.1Q, UPnP
- 31.4 cm x 18.75 cm x 4.365 cm
- 1.55 kg
- Localisation
- Europe
- 5-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Performance
- Capacity
- Routing Protocol
- HTTP, NTP
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- X.509 certificates
- IEEE 802.1Q, UPnP, VCCI, cUL, C-Tick Class B, RoHS, LVD, FCC Part 15 Class B
- Processor
- 1.7 GHz
- RAM
- 1 GB
- Flash Memory
- 128 MB
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T , LAN: 4 x 10Base-T/100Base-TX/1000Base-T
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Europe
- 31.4 cm
- 18.75 cm
- 4.365 cm
- 1.55 kg
- Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - technical support - 90 days
- 0 °C
- 45 °C
- 90% (non-condensing)
