NETGEAR Insight BR500 - Router - 4-port switch - GigE
Quicklinx: DWDYWS00 Mfr#: BR500-100UKS
£198.73 ex VAT
£238.47 inc VAT
The NETGEAR Insight VPN router is not only a high-performance router for small- to medium-size businesses, but also offers an SPI firewall.
  • Easy and secure
    The NETGEAR Insight Instant VPN router provides both secure yet easy site-to-site tunnels and secure access for remote clients.
  • Flexible operation
    You can start with one or two Instant VPN routers and as your business grows and your needs increase, you can add more devices to your VPN groups to have a complete meshed network between locations.
  • Business grade
    The rugged metal unit houses advanced, high-quality electronics.
NETGEAR Insight BR500 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
VPN throughput: 60 Mbps , LAN-to-WAN throughput: 924 Mbps
VLANs supported: 4094
Network / Transport Protocol
PPTP, L2TP, NTP, PPPoE, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
HTTP, NTP
NAT support, SPI, IPv6 support, VPN passthrough, firmware upgradable, QoS, DHCP server, DNS proxy, port forwarding, port triggering, DHCP relay, security lock slot (cable lock sold separately), ToS, DoS protection, DMZ support
IEEE 802.1Q, UPnP
31.4 cm x 18.75 cm x 4.365 cm
1.55 kg
Europe
5-year warranty
Enclosure Type
Desktop
Wireless, wired
Performance
Routing Protocol
HTTP, NTP
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
X.509 certificates
IEEE 802.1Q, UPnP, VCCI, cUL, C-Tick Class B, RoHS, LVD, FCC Part 15 Class B
1.7 GHz
RAM
1 GB
Flash Memory
128 MB
WAN: 1 x 10Base-T/100Base-TX/1000Base-T , LAN: 4 x 10Base-T/100Base-TX/1000Base-T
External power adapter
1 x network cable
Europe
31.4 cm
18.75 cm
4.365 cm
1.55 kg
Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - technical support - 90 days
45 °C
90% (non-condensing)
Type: Router
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: Ethernet
Brand: NETGEAR
