The NETGEAR Insight Managed Smart Cloud GC752X is the first 52-port Gigabit Ethernet Switch from NETGEAR with anytime, anywhere remote/cloud management. Using either the NETGEAR Insight mobile app or the Insight Cloud Portal you can easily setup, monitor and manage your Insight Managed Switches, Wireless Access Points, and business-class ReadyNAS storage. The NETGEAR GC752X features 48 copper Gigabit Ethernet ports, 2 SFP 1G and 2 SFP+ 10G fiber ports for maximum flexibility and connectivity in your network. With its remote cloud manageability, and advanced L2+/L3 Lite features, it's the most versatile switch on the market for any environment!
48-port Gigabit copper + 2-port Gigabit SFP fiber + 2-port 10-Gigabit SFP+ ports
All-inclusive connectivity with copper and 1G/10G fiber ports. -
Local and remote monitoring and management with NETGEAR Insight app
Setup, monitor and manage your network from anywhere with NETGEAR Insight iOS and Android mobile app with Insight Managed Switches, Wireless Access Points, and ReadyNAS storage devices. -
Your choice of management interface with NETGEAR Insight Cloud Portal
Monitor and manage your network from an intuitive cloud portal with advanced configuration features, as well as from the palm of your hand with the Insight mobile app. -
Remote/Cloud-managed advanced switching made affordable
Fully-integrated cloud-manageable devices; remote/cloud monitoring and management from the app is free for first two devices; after that, a subscription is required per additional device (no additional hardware required).Full duplexing, non-blocking switching with 140Gbps line rate fabricGet all the bandwidth you're paying for from 50 ports of Gigabit and 2 ports of 10-Gigabit connectivity.
- NETGEAR Smart GC752X - switch - 52 ports - smart - rack-mountable
- Switch - 52 ports - L3 - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 2 x Gigabit SFP (uplink) + 2 x 10 Gigabit SFP+ (uplink)
- Performance
- Fabric throughput: 140 Gbps , Forwarding performance (64-byte packet size): 104.2 Mpps
- Capacity
- ACL: 100 , VLANs supported: 256 , Priority queues: 8 , IGMP multicast groups: 512 , IPv4 routes (static): 32 , IPv6 routes (static): 31
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
- ARP support, IGMP snooping, Syslog support, SPI, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, LACP support, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, MVR, dual firmware images, SPQ, NDP, 2MB packet buffer, loop prevention, security lock slot (cable lock sold separately), ToS, DSCP support, cable test, administrator's password, ICMP IRDP, DNS client, 1 fan, guest access, WRR, loopback detection
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 44 cm x 22.4 cm x 4.4 cm
- 3.16 kg
- Localisation
- Europe
- 5-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- MD5, TLS 1.0, SSL 3.0, PEAP
- Authentication Method
- RADIUS, TACACS+, Extensible Authentication Protocol (EAP)
- Processor
- 1 Cortex-A9: 400 MHz
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Power, status, fan, link/activity/speed
- 48 x 10/100/1000 Base-T RJ-45 , 2 x 1000Base-X SFP uplink , 2 x 10GBase-X SFP+ uplink , USB
- Power Device
- Internal power supply
- Voltage Required
- 43.9 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 1,360,115 hours
- CCC, UL 60950-1 Second Edition, KCC, K60950-1, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class A, GB 4943.1-2011, EN 55024:2010+A1:2015, KN32, KN35, BSMI CNS13438:2006 Class A, EN 55032:2012+AC:2013 Class A, CNS 14336-1, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, EN 61000-3-2:2014 Class A, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2015 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Europe
- 44 cm
- 22.4 cm
- 4.4 cm
- 3.16 kg
- Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
