NETGEAR’s ProSAFE line of antennas and accessories for 802.11b, 802.11g and 802.11n devices give you multiple options for maximizing the reach and performance of your wireless infrastructure devices. Every WLAN deployment is unique. For outdoor bridging applications, the ANT224D10 enables two wireless N access points with antenna take-offs to create a high-speed wireless bridge between them with two streams of data. By pointing two ANT224D10 antennas at each other, they can connect two wireless access points over 10,000 meters apart. Utilizing the advantages of wireless N, the ANT224D10 provides for wireless bridging at speeds many times faster than those based on 802.11g technology. Designed for safety, the ANT224D10 includes equipment to neutralize lighting strikes and keep your access points operational. With wall mounting and pole mounting options, the ANT224D10 can be mounted in a variety of locations for maximum performance.
Versatile placement options
Designed for flexibility, this antenna can be easily mounted indoors, outdoors, on pipes, or walls, ensuring optimal signal reception no matter the location. -
Enhanced connectivity
With a frequency range of 2.4 - 2.485 GHz and a gain of 9 dBi, the antenna enhances Wi-Fi connectivity, providing a stable and strong signal across various devices. -
Durable design
Built to withstand harsh environmental conditions, this antenna operates efficiently between -30°C and 80°C and features a water-resistant construction, making it ideal for any setting. -
Easy installation
The antenna comes with a 2 m cable and a mounting kit, facilitating a hassle-free setup. Its N-Series connector ensures compatibility with a wide range of devices.
- NETGEAR ProSafe ANT2409 Indoor/Outdoor 9 dBi Omni-directional Antenna - antenna
- Product Type
- Antenna
- 0.9 kg
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, wall-mountable, indoor, pipe mountable
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.485 GHz
- Gain
- 9 dBi
- Directivity
- Omni-directional
- 2-year warranty
- Designed For
- NETGEAR DG824M, FWG114P, FWG114Pv2, WAG302 ProSafe Dual Band Wireless Access Point, WG102 ProSafe Wireless Access Point, WG302 802.11g ProSafe Wireless Access Point
- Product Type
- Antenna
- 0.9 kg
- Cable Length
- 2 m
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.485 GHz
- Gain
- 9 dBi
- Directivity
- Omni-directional
Cabling & Wiring
- Connector Provided
- 1 x N-Series connector female
- Mounting Kit
- Included
- Water-resistant
- Limited warranty - 2 years
- -30 °C
- 80 °C
- Designed For
