NETGEAR INDOOR/OUTDOOR 9DBI OMNI- DIRECTIONAL ANTENNA
Quicklinx: 73DWWS00 Mfr#: ANT2409-20000S
Type: Antennas
£104.19 ex VAT
£125.02 inc VAT
NETGEAR’s ProSAFE line of antennas and accessories for 802.11b, 802.11g and 802.11n devices give you multiple options for maximizing the reach and performance of your wireless infrastructure devices. Every WLAN deployment is unique. For outdoor bridging applications, the ANT224D10 enables two wireless N access points with antenna take-offs to create a high-speed wireless bridge between them with two streams of data. By pointing two ANT224D10 antennas at each other, they can connect two wireless access points over 10,000 meters apart. Utilizing the advantages of wireless N, the ANT224D10 provides for wireless bridging at speeds many times faster than those based on 802.11g technology. Designed for safety, the ANT224D10 includes equipment to neutralize lighting strikes and keep your access points operational. With wall mounting and pole mounting options, the ANT224D10 can be mounted in a variety of locations for maximum performance.
  • Versatile placement options
    Designed for flexibility, this antenna can be easily mounted indoors, outdoors, on pipes, or walls, ensuring optimal signal reception no matter the location.
  • Enhanced connectivity
    With a frequency range of 2.4 - 2.485 GHz and a gain of 9 dBi, the antenna enhances Wi-Fi connectivity, providing a stable and strong signal across various devices.
  • Durable design
    Built to withstand harsh environmental conditions, this antenna operates efficiently between -30°C and 80°C and features a water-resistant construction, making it ideal for any setting.
  • Easy installation
    The antenna comes with a 2 m cable and a mounting kit, facilitating a hassle-free setup. Its N-Series connector ensures compatibility with a wide range of devices.
NETGEAR ProSafe ANT2409 Indoor/Outdoor 9 dBi Omni-directional Antenna - antenna
Antenna
0.9 kg
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, wall-mountable, indoor, pipe mountable
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.485 GHz
Gain
9 dBi
Directivity
Omni-directional
NETGEAR DG824M, FWG114P, FWG114Pv2, WAG302 ProSafe Dual Band Wireless Access Point, WG102 ProSafe Wireless Access Point, WG302 802.11g ProSafe Wireless Access Point
Antenna
0.9 kg
Cable Length
2 m
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.485 GHz
Gain
9 dBi
Directivity
Omni-directional
Cabling & Wiring
Connector Provided
1 x N-Series connector female
Mounting Kit
Included
Water-resistant
-30 °C
80 °C
Type: Antennas
Brand: NETGEAR
