- NETGEAR XAVB1004 - powerline adapter - desktop
- Powerline adapter - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 200 Mbps
- Capacity
- MAC addresses: 64
- QoS, Push-and-Secure button
- IEEE 802.3, IEEE 802.3u, HomePlug AV
- Power
- AC 120/230 V (50/60 Hz)
- 13.7 cm x 10.2 cm x 2.8 cm
- 218 g
- System Requirements
- Apple MacOS X, Microsoft Windows Vista / XP / 7
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- 200 Mbps
- Capacity
- MAC addresses: 64
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, HomePlug AV, TUV, cUL, IEC 60950, UL 60950, CB, FCC Part 15 B, LVD, EMC Class B
- Status Indicators
- Power
Line Properties
- Line Coding Format
- OFDM
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- Included Accessories
- Powerline AV 200 Nano Adapter (XAV2101)
- Cables Included
- 2 x network cable - 2 m
- Localisation
- United Kingdom
- OS Required
- 13.7 cm
- 10.2 cm
- 2.8 cm
- 218 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
