NETGEAR Smart Managed Pro S350 series consists of five switch models, including 8-, 24- and 48-port Gigabit Ethernet switches and 8-, and 24-port Gigabit Ethernet PoE+ switches with 2 or 4 SFP ports for fiber uplinks, offering powerful Layer 2 features, enhanced performance and ease of use. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. Advanced features such as L2/L3/L4 Access Control Lists (ACLs), Quality of Service (QoS), Link Aggregation Control Protocol (LACP) and Spanning Tree Protocol (STP) will ensure a high-speed and highly secured network environment for your business.
Robust security
With support for RADIUS and TACACS+ authentication methods, alongside a comprehensive Access Control List (ACL), the NETGEAR Smart GS348T ensures secure network access and precise control over user permissions. -
Efficient performance
Equipped with a 104 Gbps switch fabric speed and a forwarding performance of 77.3 Mpps, this switch is designed to handle substantial data traffic, ensuring efficient data flow across the network. -
Extensive connectivity
Featuring 48 RJ-45 connectors for 1000Base-T and 4 SFP slots for 1000Base-X connections, the GS348T offers versatile connectivity options for a wide range of network requirements. -
Advanced network features
From VLAN support to Quality of Service (QoS) and port mirroring, the GS348T comes packed with features to manage traffic, prioritize services, and secure your network infrastructure. -
Easy management
Manageable via HTTP, HTTPS, SNMP, and more, the GS348T provides a flexible and intuitive interface for configuring, managing, and monitoring the network, simplifying network administration tasks.
- NETGEAR Smart GS348T - switch - 48 ports - smart - rack-mountable
- Switch - 48 ports - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 4 x SFP
- Performance
- Switch fabric speed: 104 Gbps , Forwarding performance (64-byte packet size): 77.3 Mpps
- Capacity
- ACL: 100 , IGMP multicast groups: 512 , Priority queues: 8 , DHCP snooping entries: 8000
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
- VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, LACP support, DHCP client, dual firmware images, SPQ, CoS, SP, ToS, DSCP support, 1.5MB packet buffer, cable test, rate limit, IGMP querier, 1 fan, Voice VLAN, VLAN management, Guest VLAN, WRR, MAC based VLAN, Auto VoIP, MAC lockdown, SNTP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- 44 cm x 20.6 cm x 4.3 cm
- 3.05 kg
- Localisation
- Europe
- 5-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- TLS
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 400 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Power, link/activity, fan, speed
- 48 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP
- Power Device
- Internal power supply
- Installed Qty
- 1
- 39.1 watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 1,271,842 hours
- BSMI CNS 13438 Class A, EN 60950, UL 1950, SCC, CNS 14336, EN 61000-3-3:2013, EN 55024:2010, YD/T993-1998, FCC CFR47 Part 15 A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Europe
- 44 cm
- 20.6 cm
- 4.3 cm
- 3.05 kg
- Limited warranty - 5 years , Limited warranty - replacement - 5 years - response time: next business day , Technical support - phone consulting - 90 days
- 0 °C
- 45 °C
- 95% (non-condensing)
