NETGEAR Smart Managed Pro S350 series consists of five switch models, including 8-, 24- and 48-port Gigabit Ethernet switches and 8-, and 24-port Gigabit Ethernet PoE+ switches with 2 or 4 SFP ports for fiber uplinks, offering powerful Layer 2 features, enhanced performance and ease of use. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. Advanced features such as L2/L3/L4 Access Control Lists (ACLs), Quality of Service (QoS), Link Aggregation Control Protocol (LACP) and Spanning Tree Protocol (STP) will ensure a high-speed and highly secured network environment for your business.
Enhanced security
With support for Access Control List (ACL), DHCP snooping, and advanced encryption algorithms like TLS, this switch ensures a secure network environment, preventing unauthorized access and protecting sensitive data. -
Efficient performance
Featuring a switch fabric speed of 52 Gbps and a forwarding performance of 38.6 Mpps, the NETGEAR Smart GS324TP delivers efficient handling of data across the network, ensuring high-speed connectivity and reliable performance. -
Comprehensive connectivity
Equipped with 24 PoE+ ports and 2 SFP ports, this switch offers versatile connection options for various devices, including high-power wireless access points, surveillance cameras, and VoIP phones, while ensuring compatibility with fiber connections. -
Intelligent network management
Smart features like Quality of Service (QoS), VLAN support, and port mirroring enable sophisticated management of network traffic, ensuring optimal performance for critical applications and services. -
Durable and reliable
With a mean time between failures (MTBF) of over 1.3 million hours and a comprehensive set of compliance standards, this switch is built for longevity and dependable operation in diverse environments.
- NETGEAR Smart GS324TP - switch - 24 ports - smart - rack-mountable
- Switch - 24 ports - smart
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 190 W
- Performance
- Switch fabric speed: 52 Gbps , Forwarding performance (64-byte packet size): 38.6 Mpps
- Capacity
- ACL: 100 , IGMP multicast groups: 512 , Priority queues: 4 , DHCP snooping entries: 8000
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
- VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, LACP support, DHCP client, 512KB packet buffer, dual firmware images, SPQ, CoS, SP, ToS, DSCP support, 2 fans, cable test, rate limit, IGMP querier, Voice VLAN, VLAN management, Guest VLAN, WRR, MAC based VLAN, Auto VoIP, MAC lockdown, SNTP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- 33 cm x 20.6 cm x 4.3 cm
- 2.69 kg
- Localisation
- Europe
- 5-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 190 W
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- TLS
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 800 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- Status Indicators
- Power, PoE, link/activity, fan, speed
- 24 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- Installed Qty
- 1
- 229.9 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 1,328,429 hours
- BSMI CNS 13438 Class A, EN 60950, UL 1950, SCC, CNS 14336, EN 61000-3-3:2013, EN 55024:2010, YD/T993-1998, FCC CFR47 Part 15 A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Europe
- 33 cm
- 20.6 cm
- 4.3 cm
- 2.69 kg
- Limited warranty - 5 years , Limited warranty - replacement - 5 years - response time: next business day , Technical support - phone consulting - 90 days
- 0 °C
- 45 °C
- 95% (non-condensing)
