NETGEAR Smart Managed Pro S350 series consists of five switch models, including 8-, 24- and 48-port Gigabit Ethernet switches and 8-, and 24-port Gigabit Ethernet PoE+ switches with 2 or 4 SFP ports for fiber uplinks, offering powerful Layer 2 features, enhanced performance and ease of use. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. Advanced features such as L2/L3/L4 Access Control Lists (ACLs), Quality of Service (QoS), Link Aggregation Control Protocol (LACP) and Spanning Tree Protocol (STP) will ensure a high-speed and highly secured network environment for your business.
Robust security
Equipped with RADIUS and TACACS+ authentication methods alongside Access Control List (ACL) support, this switch ensures secure network access control and management, safeguarding your data from unauthorized access. -
High performance
With a switch fabric speed of 52 Gbps and forwarding performance capable of handling 38.6 Mpps, the NETGEAR Smart GS324T efficiently manages traffic, ensuring smooth and reliable data transmission across the network. -
Advanced networking features
Features such as IGMP snooping, Quality of Service (QoS), VLAN support, and Link Aggregation Control Protocol (LACP) support provide enhanced network efficiency, segmentation, and prioritization of traffic, catering to diverse networking needs. -
Extensive connectivity
This switch comes with 24 1000Base-T ports and 2 SFP (mini-GBIC) ports, offering ample connectivity options for devices and uplink to other networks, making it a versatile choice for expanding your network infrastructure. -
Efficient management
Manageable via SNMP, RMON, HTTP, and HTTPS, the NETGEAR Smart GS324T allows for easy configuration and monitoring, ensuring optimal performance and simplifying network management tasks.
 - NETGEAR Smart GS324T - switch - 24 ports - smart - rack-mountable
 - Switch - 24 ports - smart
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000 + 2 x SFP
- Performance
 - Switch fabric speed: 52 Gbps , Forwarding performance (64-byte packet size): 38.6 Mpps
- Capacity
 - ACL: 100 , IGMP multicast groups: 512 , Priority queues: 4 , DHCP snooping entries: 8000
- MAC Address Table Size
 - 16K entries
- Jumbo Frame Support
 - 9216 bytes
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
 - SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
 - VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, fanless, LACP support, DHCP client, 512KB packet buffer, dual firmware images, SPQ, CoS, SP, ToS, DSCP support, cable test, rate limit, IGMP querier, Voice VLAN, VLAN management, Guest VLAN, WRR, MAC based VLAN, Auto VoIP, MAC lockdown, SNTP client
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
 - 32.8 cm x 16.9 cm x 4.3 cm
 - 1.62 kg
- Localisation
 - Europe
 - 5-year warranty
- Enclosure Type
 - Desktop, rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
- Performance
- Capacity
 - 16K entries
 - 9216 bytes
- Routing Protocol
- Encryption Algorithm
 - TLS
- Authentication Method
 - RADIUS, TACACS+
- Processor
 - : 800 MHz
- RAM
 - 512 MB
- Flash Memory
 - 128 MB
- Status Indicators
 - Power, link/activity, speed
 - 24 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
- Power Device
 - Internal power supply
- Installed Qty
 - 1
 - 13.5 Watt
- Included Accessories
 - Rubber feet
- Rack Mounting Kit
 - Included
- MTBF
 - 1,999,947 hours
 - BSMI CNS 13438 Class A, EN 60950, UL 1950, SCC, CNS 14336, EN 61000-3-3:2013, EN 55024:2010, YD/T993-1998, FCC CFR47 Part 15 A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
 - Europe
 - 32.8 cm
 - 16.9 cm
 - 4.3 cm
 - 1.62 kg
 - Limited warranty - 5 years , Limited warranty - replacement - 5 years - response time: next business day , Technical support - phone consulting - 90 days
 - 0 °C
 - 45 °C
 - 95% (non-condensing)
