NETGEAR GS324T 24-port 2xSFP Smart Switch
Quicklinx: F63NWS00 Mfr#: GS324T-100EUS
NETGEAR Smart Managed Pro S350 series consists of five switch models, including 8-, 24- and 48-port Gigabit Ethernet switches and 8-, and 24-port Gigabit Ethernet PoE+ switches with 2 or 4 SFP ports for fiber uplinks, offering powerful Layer 2 features, enhanced performance and ease of use. They are purposely designed for converged networks where voice, video, data are all carried on a single network platform. Advanced features such as L2/L3/L4 Access Control Lists (ACLs), Quality of Service (QoS), Link Aggregation Control Protocol (LACP) and Spanning Tree Protocol (STP) will ensure a high-speed and highly secured network environment for your business.
  • Robust security
    Equipped with RADIUS and TACACS+ authentication methods alongside Access Control List (ACL) support, this switch ensures secure network access control and management, safeguarding your data from unauthorized access.
  • High performance
    With a switch fabric speed of 52 Gbps and forwarding performance capable of handling 38.6 Mpps, the NETGEAR Smart GS324T efficiently manages traffic, ensuring smooth and reliable data transmission across the network.
  • Advanced networking features
    Features such as IGMP snooping, Quality of Service (QoS), VLAN support, and Link Aggregation Control Protocol (LACP) support provide enhanced network efficiency, segmentation, and prioritization of traffic, catering to diverse networking needs.
  • Extensive connectivity
    This switch comes with 24 1000Base-T ports and 2 SFP (mini-GBIC) ports, offering ample connectivity options for devices and uplink to other networks, making it a versatile choice for expanding your network infrastructure.
  • Efficient management
    Manageable via SNMP, RMON, HTTP, and HTTPS, the NETGEAR Smart GS324T allows for easy configuration and monitoring, ensuring optimal performance and simplifying network management tasks.
NETGEAR Smart GS324T - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x SFP
Performance
Switch fabric speed: 52 Gbps , Forwarding performance (64-byte packet size): 38.6 Mpps
ACL: 100 , IGMP multicast groups: 512 , Priority queues: 4 , DHCP snooping entries: 8000
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP
VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, fanless, LACP support, DHCP client, 512KB packet buffer, dual firmware images, SPQ, CoS, SP, ToS, DSCP support, cable test, rate limit, IGMP querier, Voice VLAN, VLAN management, Guest VLAN, WRR, MAC based VLAN, Auto VoIP, MAC lockdown, SNTP client
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
32.8 cm x 16.9 cm x 4.3 cm
1.62 kg
Europe
5-year warranty
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
TLS
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Power, link/activity, speed
24 x 1000Base-T RJ-45 ¦ 2 x 1000Base-X SFP
Internal power supply
Installed Qty
1
13.5 watt
Rubber feet
Rack Mounting Kit
Included
MTBF
1,999,947 hours
BSMI CNS 13438 Class A, EN 60950, UL 1950, SCC, CNS 14336, EN 61000-3-3:2013, EN 55024:2010, YD/T993-1998, FCC CFR47 Part 15 A, GB 4943.1-2011, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, ICES-003:2016 issue 6 Class A, CISPR 32:2012, VCCI-CISPR 32:2016 Class A, AS/NZS CISPR32:2013 Class A, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Europe
32.8 cm
16.9 cm
4.3 cm
1.62 kg
Limited warranty - 5 years , Limited warranty - replacement - 5 years - response time: next business day , Technical support - phone consulting - 90 days
45 °C
95% (non-condensing)
