NETGEAR GS116LP 16 port Rack-Mountable Switch
Quicklinx: DTF1WS00 Mfr#: GS116LP-100EUS
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
£128.60 ex VAT
£154.32 inc VAT
The NETGEAR Gigabit unmanaged switch series helps businesses cost-effectively expand their network to Gigabit speeds and higher port counts.
  • Quality components and energy efficiency
    Unmanaged Gigabit switches are built with quality components to assure a long life. Unmanaged switches are built to last, and rigorously tested to provide the reliability businesses need.
  • Instant connectivity
NETGEAR GS116LP - switch - 16 ports - rack-mountable
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
76 W
Performance
Bandwidth: 32 Gbps
MAC Address Table Size
4K entries
Flow control, full duplex capability, store and forward, WFQ, QoS, Jumbo Frames support, fanless, Energy Efficient Ethernet, 1MB packet buffer, CoS, DSCP support, EEE, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
DC 54 V
28.6 cm x 10.2 cm x 2.7 cm
880 g
United Kingdom, Europe
Switch - 16 ports
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
76 W
Performance
Bandwidth: 32 Gbps
4K entries
Status Indicators
Power, PoE, link/activity/speed
16 x 1000Base-T RJ-45 PoE+ - 76 W
External power adapter
DC 54 V
Wall mounting kit
Rack Mounting Kit
Included
MTBF
2,088,514 hours
VCCI, BSMI, ICES-003, CB, FCC Part 15, EN 60950-1, LVD, KC, EAC, RCM
28.6 cm
10.2 cm
2.7 cm
880 g
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 16
Managed: No
POE: PoE+
Brand: NETGEAR
