NetGear Gigabit Ethernet 10/100/1000 Mbps 8 port Switch 200 Series
Quicklinx: 8F4FWS00 Mfr#: GS208-100UKS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: No
More than 50 in stock
£17.08 ex VAT
£20.49 inc VAT
The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
NETGEAR GS208 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4K entries
Auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
15.2 cm x 9.3 cm x 2.6 cm
192 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
4K entries
Status Indicators
Power, link/activity
8 x 1000Base-T RJ-45
External power adapter
3.64 Watt
United Kingdom
15.2 cm
9.3 cm
2.6 cm
192 g
10 - 90% (non-condensing)
8F4F C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
8F4F C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
8F4F C2G 2m Cat6a Shielded Patch - Blue In Stock £7.05
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
