The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
- NETGEAR GS208 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Bandwidth: 16 Gbps
- MAC Address Table Size
- 4K entries
- Auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
- 15.2 cm x 9.3 cm x 2.6 cm
- 192 g
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 4K entries
- Status Indicators
- Power, link/activity
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- 3.64 Watt
- Localisation
- United Kingdom
- 15.2 cm
- 9.3 cm
- 2.6 cm
- 192 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.73 |
