NetGear Gigabit Ethernet 10/100/1000 Mbps 5port Switch 200 Series
Quicklinx: 8F4CWS00 Mfr#: GS205-100UKS
The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
  • Efficient connectivity
    The NETGEAR GS205 switch offers seamless connectivity with its five 10/100/1000 ports, ensuring high-speed network access for multiple devices. Its auto-uplink (auto MDI/MDI-X) feature automatically adjusts for straight-through or crossover cables, simplifying setup and maintenance.
  • Reliable performance
    Designed for efficiency, the switch features a store and forward mechanism to minimize packet loss, and a robust 4K entry MAC address table that accommodates a large number of network devices. This combination ensures a smooth and reliable network experience.
  • Easy monitoring
    With status indicators for link/activity and power, monitoring the network's status is straightforward. These indicators provide real-time feedback, making it easier to diagnose and resolve any issues promptly.
NETGEAR GS205 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
MAC Address Table Size
4K entries
Auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
11.4 cm x 8.6 cm x 2.6 cm
122 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
4K entries
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
External power adapter
3.56 Watt
United Kingdom
11.4 cm
8.6 cm
2.6 cm
122 g
10 - 90% (non-condensing)
8F4C C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
8F4C C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
