NETGEAR FS108 - switch - 8 ports 10/100
Customer rating: 5.0* (Write a review)
Quicklinx: 6KXWS00 Mfr#: FS108UK
NETGEAR's FS100 series Fast Ethernet Switches provide your LAN with high-speed, 10/100 Mbps auto-sensing connectivity for as many as 5, 8, or 16 users. Just plug in your Ethernet cables, connect a power cord, and you're ready to go - there's no software to configure. Engineered without the need for internal fans, they operate silently. And each of these very compact switches is housed in a sturdy metal case for years of dependable use. When you want greater bandwidth and increased network access for your growing business, plus the added benefit of quiet operation, NETGEAR's FS105, FS108, and FS116 are your best choices for quality, convenience, and smooth-running usability - all at very affordable prices.
NETGEAR FS108 10/100 Desktop Switch - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
8 x 10/100
MAC Address Table Size
8K entries
Full duplex capability, uplink, MDI/MDI-X switch
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
23.5 cm x 10.3 cm x 2.7 cm
0.7 kg
NETGEAR lifetime warranty
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
8K entries
Status Indicators
Collision status, port transmission speed, power, link OK, transmit, receive, link/activity
8 x 100Base-TX RJ-45
External power adapter
12.5 Watt
Mounting Kit
Included
FCC Class A certified, VCCI, C-Tick
23.5 cm
10.3 cm
2.7 cm
0.7 kg
0 - 90%
Customer reviews
Write a review for the NETGEAR FS108 - switch - 8 ports 10/100 here!
ooo a switch!
Reviewed by Anonymous Review Posted 28/11/2003
Good value switch (when i bought it, it cost well over £170!), with sturdy design.
No fan, passive cooling, so silent.
Runs hot to the touch tho, so I stuck a couple of P3 heatsinks on it.
Running 24/7 now for over 2 years with no problems or dead PSU yet.... (fingers crossed). Runs with lower ampage than the DS108, so can be hooked up to a UPS no probs.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Good little switch, but unreliable?
Reviewed by Dave. Review Posted 14/06/2004
Bought three of these towards the end of 2002. Despite the apparently high build quality (solid-feeling metal case), one of them expired after 18 months. Good job they have a 5-year warranty!
However, that aside, they perform well, and are fanless, so silent in operation. The auto-sensing uplink is also a boon, but most similar devices seem to have this feature now. Not much else you can say about a switch - it does the job!
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
