NETGEAR Fibre Gigabit Module
Quicklinx: 334SWS00 Mfr#: AGM731F
Type: Modules
More than 50 In Stock
£106.73 ex VAT
£128.07 inc VAT
The ProSAFE GBIC Module is a LC duplex connector and meets SFP GBIC standard for use with any SFP GBIC compliant slot.
NETGEAR ProSafe AGM731F - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
1GbE
1.3 cm x 6.5 cm x 0.9 cm
50 g
NETGEAR M4300-28G-PoE+
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Full duplex capability
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode
Compatible Slots
1 x SFP (mini-GBIC)
UL 1950
1.3 cm
6.5 cm
0.9 cm
50 g
10 - 90%
Type: Modules
Brand: NETGEAR
