NETGEAR Fibre Gigabit 1000Base-SX (LC) SFP Module
Quicklinx: F6K3WS00 Mfr#: AGM731F-AO
Type: Modules
£17.00 ex VAT
£20.40 inc VAT
This Netgear AGM731F compatible SFP transceiver provides 1000Base-SX throughput up to 550m over multi-mode fiber (MMF) at a wavelength of 850nm using a LC connector. It is guaranteed to be 100% compatible with the equivalent Netgear transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Netgear, as well as to comply with MSA (Multi-Source Agreement) standards to ensure seamless network integration.
AddOn Netgear AGM731F Compatible SFP Transceiver - SFP (mini-GBIC) transceiver module - 1GbE
Plug-in module
Cabling Type
1000Base-SX
Optical Wave Length
850 nm
1GbE
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Optical Wave Length
850 nm
1 x Ethernet 1000Base-SX
Compatible Slots
SFP (mini-GBIC)
Type: Modules
Brand: NETGEAR
