Boost your existing network range, delivering dual band Wi-Fi up to 1.9Gbps. It works with any standard Wi-Fi router and is ideal for HD video streaming and gaming with one Gigabit Ethernet port. The compact wall-plug design allows you to simply plug your AC1900 Wi-Fi Range Extender Essentials Edition into any electrical outlet, and smart LED indicator lights help you place it for optimal boost in range and performance.
Boost Wi-Fi
Improve the range of your existing Wi-Fi network. -
FastLane technology
Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming & gaming. -
Ethernet port
Connect a wired device like a game console or a smart TV to your Wi-Fi network. -
Simultaneous Dual Band Wi-Fi
Extend 2.4 & 5GHz Wi-Fi up to 1900 Mbps & reduce interference. -
Secure setup
Push 'N' Connect using Wi-Fi Protected Setup (WPS) connects computers and/or routers to the Extender quickly and securely. -
Two Wi-Fi modes
Extend existing Wi-Fi connection or create a new AC Wi-Fi access point.
- NETGEAR AC1900 WiFi Range Extender EX6400 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 16.1 cm x 8.14 cm x 4.45 cm
- 300 g
- 16.1 cm
- 8.14 cm
- 4.45 cm
- 300 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1900 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Access Point operational mode, Wi-Fi Protected Setup (WPS), Push āNā Connect button, FastLane Technology
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- 1 x 1000Base-T - RJ-45
- Power Device
- Internal power supply
