NETGEAR EX6400 Wi-Fi Range Extender 802.11a/b/g/n/ac - Dual Band
Quicklinx: CDWHWS00 Mfr#: EX6400-100UKS
  • IEEE 802.11n
Boost your existing network range, delivering dual band Wi-Fi up to 1.9Gbps. It works with any standard Wi-Fi router and is ideal for HD video streaming and gaming with one Gigabit Ethernet port. The compact wall-plug design allows you to simply plug your AC1900 Wi-Fi Range Extender Essentials Edition into any electrical outlet, and smart LED indicator lights help you place it for optimal boost in range and performance.
  • Boost Wi-Fi
    Improve the range of your existing Wi-Fi network.
  • FastLane technology
    Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming & gaming.
  • Ethernet port
    Connect a wired device like a game console or a smart TV to your Wi-Fi network.
  • Simultaneous Dual Band Wi-Fi
    Extend 2.4 & 5GHz Wi-Fi up to 1900 Mbps & reduce interference.
  • Secure setup
    Push 'N' Connect using Wi-Fi Protected Setup (WPS) connects computers and/or routers to the Extender quickly and securely.
  • Two Wi-Fi modes
    Extend existing Wi-Fi connection or create a new AC Wi-Fi access point.
NETGEAR AC1900 WiFi Range Extender EX6400 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
16.1 cm x 8.14 cm x 4.45 cm
300 g
16.1 cm
8.14 cm
4.45 cm
300 g
United Kingdom
External
Wireless
Data Transfer Rate
1900 Mbps
Frequency Band
2.4 GHz, 5 GHz
Access Point operational mode, Wi-Fi Protected Setup (WPS), Push ā€˜N’ Connect button, FastLane Technology
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
1 x 1000Base-T - RJ-45
Internal power supply
