NETGEAR AC1900 Dual Band WiFi Mesh Extender boosts WiFi coverage with your existing home WiFi to create a powerful mesh WiFi for greater wireless speed & coverage. It works with any standard WiFi router & is ideal for HD video streaming & gaming. Get the connectivity you need for iPads, smartphones, laptops & more.
Mesh Wi-Fi
Easily create a whole-home mesh Wi-Fi with your existing router. -
Push-button setup
The extender provides an easy setup with a push of the button. -
One Wi-Fi name
It extends coverage of your home's Wi-Fi with same Wi-Fi name & security password. -
Gigabit Ethernet port
Connect a wired device like Blu-ray player, game console, smart TV or streaming player to your Wi-Fi network. -
FastLane technology
Use both Wi-Fi bands to establish one high-speed connection; ideal for HD streaming & gaming. -
Smart roaming
It automatically connects your mobile devices to the best available Wi-Fi.
- NETGEAR EX6410 - Wi-Fi range extender - Wi-Fi 5, Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 16.1 cm x 8.14 cm x 4.45 cm
- 300 g
- 2-year warranty
- 16.1 cm
- 8.14 cm
- 4.45 cm
- 300 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Wi-Fi Rating
- AC1900
- Access Point operational mode, Wi-Fi Protected Setup (WPS), dual band, Smart Roaming, Push 'N' Connect button
- Encryption Algorithm
- AES, WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac
Aerial
- Antenna
- Internal
- 1 x 1000Base-T - RJ-45
- OS Provided
- No operating system
- Limited warranty - 2 days
