NETGEAR EX6130 Wi-Fi Range Extender 802.11a/b/g/n/ac - Dual Band
Quicklinx: CDWGWS00 Mfr#: EX6130-100UKS
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 1200Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: Mac, PC
  • IEEE 802.11n
29 in stock
£46.32 ex VAT
£55.58 inc VAT
The NETGEAR Wi-Fi range extender increases the distance of a Wi-Fi network by boosting the existing Wi-Fi signal and enhancing the overall signal quality over long distances. An extender repeats the signals from an existing Wi-Fi router or access point.
NETGEAR EX6130 - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
AC 230V
5.5 cm x 3.4 cm x 11.4 cm
195 g
5.5 cm
3.4 cm
11.4 cm
195 g
United Kingdom
External
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, status, WPS
Routing, auto-sensing per device, Wi-Fi Protected Setup (WPS), integrated power socket, Push ā€˜Nā€™ Connect button, reset button, integrated power plug
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX - RJ-45
Internal power supply
AC 230V
Speed: 1200Mbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
