NETGEAR EX6130 Wi-Fi Range Extender 802.11a/b/g/n/ac - Dual Band
Quicklinx: CDWGWS00 Mfr#: EX6130-100UKS
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 1200Mbps
Protocol: IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac + 1 more
Compatibility: Mac, PC
  • IEEE 802.11n
£46.07 ex VAT
£55.28 inc VAT
The NETGEAR Wi-Fi range extender increases the distance of a Wi-Fi network by boosting the existing Wi-Fi signal and enhancing the overall signal quality over long distances. An extender repeats the signals from an existing Wi-Fi router or access point.
  • Enhanced connectivity
    With dual-band Wi-Fi support across 2.4 GHz and 5 GHz bands, the NETGEAR EX6130 ensures a more stable and faster wireless connection. This versatility allows devices to switch between bands based on signal strength, reducing dropped connections and enhancing overall Internet speed.
  • Secure and easy setup
    The device features multiple encryption protocols including WEP, WPA-PSK, and WPA2-PSK, ensuring your network remains secure against unauthorized access. Additionally, the Push ā€˜N' Connect button and Wi-Fi Protected Setup (WPS) make it incredibly easy to connect new devices securely with the press of a button.
  • Versatile performance
    Equipped with an integrated power plug and socket, the NETGEAR EX6130 does not occupy unnecessary space, allowing you to plug in other devices alongside it. The auto-sensing per device feature optimizes the connection for each device, ensuring efficient data transfer rates of up to 1200 Mbps.
  • Comprehensive compatibility
    Designed to work seamlessly with both Mac and PC, the NETGEAR EX6130 offers broad compatibility. Its external detachable antennas enhance signal reach, ensuring that your Wi-Fi coverage extends to every corner of your home or office.
  • Intelligent design
    The Wi-Fi range extender comes with integrated status indicators for WPS, power, and status, providing real-time feedback on the device's performance. The reset button allows for quick troubleshooting, ensuring your network remains up and running with minimal interruptions.
NETGEAR EX6130 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
AC 230V
5.5 cm x 3.4 cm x 11.4 cm
195 g
5.5 cm
3.4 cm
11.4 cm
195 g
United Kingdom
External
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, status, WPS
Routing, auto-sensing per device, Wi-Fi Protected Setup (WPS), integrated power socket, Push ā€˜N’ Connect button, reset button, integrated power plug
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX - RJ-45
Internal power supply
AC 230V
Speed: 1200Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Compatibility: Mac
Compatibility: PC
Brand: NETGEAR
