The NETGEAR Wi-Fi range extender increases the distance of a Wi-Fi network by boosting the existing Wi-Fi signal and enhancing the overall signal quality over long distances. An extender repeats the signals from an existing Wi-Fi router or access point.
Enhanced connectivity
With dual-band Wi-Fi support across 2.4 GHz and 5 GHz bands, the NETGEAR EX6130 ensures a more stable and faster wireless connection. This versatility allows devices to switch between bands based on signal strength, reducing dropped connections and enhancing overall Internet speed. -
Secure and easy setup
The device features multiple encryption protocols including WEP, WPA-PSK, and WPA2-PSK, ensuring your network remains secure against unauthorized access. Additionally, the Push āN' Connect button and Wi-Fi Protected Setup (WPS) make it incredibly easy to connect new devices securely with the press of a button. -
Versatile performance
Equipped with an integrated power plug and socket, the NETGEAR EX6130 does not occupy unnecessary space, allowing you to plug in other devices alongside it. The auto-sensing per device feature optimizes the connection for each device, ensuring efficient data transfer rates of up to 1200 Mbps. -
Comprehensive compatibility
Designed to work seamlessly with both Mac and PC, the NETGEAR EX6130 offers broad compatibility. Its external detachable antennas enhance signal reach, ensuring that your Wi-Fi coverage extends to every corner of your home or office. -
Intelligent design
The Wi-Fi range extender comes with integrated status indicators for WPS, power, and status, providing real-time feedback on the device's performance. The reset button allows for quick troubleshooting, ensuring your network remains up and running with minimal interruptions.
- NETGEAR EX6130 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Power
- AC 230V
- 5.5 cm x 3.4 cm x 11.4 cm
- 195 g
- 2-year warranty
- 5.5 cm
- 3.4 cm
- 11.4 cm
- 195 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1200 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, status, WPS
- Routing, auto-sensing per device, Wi-Fi Protected Setup (WPS), integrated power socket, Push āNā Connect button, reset button, integrated power plug
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V
- Limited warranty - 2 years
