NETGEAR DGN1000 Wireless-N 150 Modem Router ADSL
Quicklinx: 6JPYWS00 Mfr#: DGN1000-100UKS
  • IEEE 802.11n
The NETGEAR N150 Wireless ADSL2+ Modem Router is a simple and secure way to share your high-speed Internet connection at Wireless-N speeds for surfing the Internet, email, online chat and Facebook. Complete with all-in-one DSL modem and WiFi router, it is compatible with all major DSL Internet service providers and Wireless-G networks, allowing hassle-free connection flexibility.
All-in-one DSL modem -- ADSL2+ modem and router combined create complete gateway for DSL Internet connection
Compatibility -- Compatible with all major DSL Internet service providers (ISPs).
Surf, email, chat -- Wireless-N connection for basic Internet applications like surfing the Web, email and Facebook
Share Internet connection -- Allows Internet broadband sharing and the freedom of wireless Internet usage
Live Parental Controls -- Keeps your Internet experience safe
Blocks unsafe Internet content and applications and can be managed from anywhere
Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
To learn more visit www.netgear.com/lpc
Secured connection -- Push `N' Connect offers a secured wireless Internet connection at the push of a button
NETGEAR Green features -- Power and Wi-Fi on/off buttons, Energy Star-compliant power adapter and 80% recycled packaging
NETGEAR DGN1000 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, SPI, DoS attack prevention, IDS, VPN passthrough, IPS, wall mountable, WMM support, event log, WPS, DHCP server, Live Parental Controls, Push ‘N’ Connect button
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
AC 230V (50 Hz)
Environmental Standards
ENERGY STAR Qualified
17.8 cm x 13 cm x 3.1 cm
265 g
United Kingdom
1-year warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Routing Protocol
RIP-1, RIP-2
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, VCCI Class B ITE, CISPR 22 Class B, EN55022 Class B, FCC Part 15 B, RoHS, WEEE, CEC
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
Antenna Qty
1
Gain Level
2 dBi
External power adapter
AC 230V (50 Hz)
ENERGY STAR Certified
1 x network cable , 1 x phone cable
United Kingdom
Software Included
Drivers & Utilities
17.8 cm
13 cm
3.1 cm
265 g
Limited warranty - 1 year
10 - 90% (non-condensing)
Resources
The following resources are available for the NETGEAR DGN1000 Wireless-N 150 Modem Router ADSL
