NetGear DG834G Wireless BT ADSL Modem/Router & Firewall 802.11g
Customer rating: 4.0* (Write a review)
Quicklinx: 2VCDWS00 Mfr#: DG834UK
  • Wi-Fi CERTIFIED
Wireless Connectivity
The DG834G 54 Mbps Wireless ADSL modem router provides continuous, untethered access to network resources and the Internet. The DG834G allows you to share your hi-speed ADSL broadband connection wirelessly with all the desktop PC’s, laptops and games consoles in the household or small office. A built-in 4 port switch also enables you to connect some computers using cables if you prefer.
Safe and Secure
The built-in True Firewall features Stateful Packet Inspection (SPI) and Denial of Service (DOS), which operate as your first line of attack against intruders. The DG834G provides both WEP and WPA-PSK wireless encryption standards to protect your network from eavesdroppers and bandwidth pinchers! Content filtering lets you control access to inappropriate websites and limit usage by time of day. To be ultimately secure you can limit access to designated computers using their unique ID, called a MAC address.
Easy to Set-up
The DG834G 54 Mbps wireless router is simple to use – it plugs directly into your ADSL line, no need for a separate modem. Set-up could not be easier; NETGEAR’s Smart Wizard install assistant automatically detects and makes the best connection to your ISP (Internet Service Provider). It is also easy to change the settings of your DG834G wireless router via a web-browser interface.
NETGEAR DG834Gv5 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
IPSec VPN tunnels: 5
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DMZ port, auto-sensing per device, NAT support, VPN support, SPI, DoS attack prevention, E-mail alert, WDS support, URL filtering, WMM support, WPS, DHCP server, DNS proxy, Green Ethernet
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED
Environmental Standards
ENERGY STAR Qualified
17.5 cm x 11.9 cm x 2.8 cm
300 g
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT) Annex A
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
External power adapter
ENERGY STAR Certified
Vertical stand
1 x network cable , 1 x phone cable
United Kingdom
Software Included
Drivers & Utilities
17.5 cm
11.9 cm
2.8 cm
300 g
Customer reviews
Write a review for the NetGear DG834G Wireless BT ADSL Modem/Router & Firewall 802.11g here!
Very Pleased
Reviewed by Anonymous Review Posted 07/07/2005
Was looking for a reliable router and stubled on this, and found that it works like a dream. I can walk around the house without ever losing the connection. Brought with a Dabsvalue PCMICIA card, slightly more expensive but worth it. Works with tiscali so im happy.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Easy set-up great looking product
Reviewed by Anonymous Review Posted 22/02/2004
Quick delivery from dabs, no hastle. Got the unit up and running in ten minutes and found connection speeds excellent throughout my home, I also purchased the WG511 PC card and WG121 USB adapter for my laptop and desktop and found that set-up on these were also very straight forward. I purchased on a recommendation from Digital Home Magazine where the DG834G had recently won an award.
  • Overall 5*
  • Ease of use 5*
Hassle Free Wireless Connectivity!
Reviewed by Anonymous Review Posted 27/07/2005
Reviewed following six very successful months use by a non-techie user with OneTel broadband. I originally bought this router with the sole intention of freeing up my Dell Centrino lap top. Within a week I’d bought a USB stick for my antiquated Siemens Xpert desktop (Dabs Value - EW-7317UG). The unit was pre-installed with the latest firmware and has been absolutely problem free. Tying MAC addresses down was easy, using the WEP feature was easy. This router is currently supporting the Dell laptop, the same antiquated Siemens desktop, a Palm T3 with wi-fi card and just lately, two Apple iBooks belonging to visiting friends. Really hassle free!
  • Overall 5*
  • Ease of use 5*
Read all 103 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
