NETGEAR DG834 BT ADSL Firewall Modem/Router
Customer rating: 5.0* (Write a review)
Quicklinx: 2SR0WS00 Mfr#: DG834UK
Four products in one, this multitalented firewall router combines an ADSL modem, router, four-port 10/100 LAN switch, and SPI Double Firewall to deliver broadband access that's continuously available for sharing with all your networked devices. Simple to use, it plugs directly into your ADSL line for instant connectivity to network resources and the Internet, and an integrated switch lets you directly connect up to four computers or any combination of four computers, access points or printers. Setup couldn't be easier with NETGEAR's unique Smart Wizard install assistant helps to guide you each step of the way. The Smart Wizard also automatically detects and makes the optimal connection to your ISP while the Double Firewall protects your network with business-class security against intruders, including logs and alerts of break-in attempts. VPN pass-through makes it safe to connect to your business network from home or office. The DG834 router's sleek, contemporary design is attractive for the home/office environment.
NETGEAR DG834 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL Lite, ADSL
WAN Ports Qty
1
Ethernet, Fast Ethernet
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP
Routing Protocol
RIP, static IP routing
Remote Management Protocol
HTTP
Full duplex capability, firewall protection, DMZ port, auto-sensing per device, dynamic IP address assignment, DHCP support, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), SPI, DoS attack prevention, manageable, E-mail alert, VPN passthrough, URL filtering
UPnP
2.8 cm x 11.9 cm x 17.5 cm
300 g
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98/ME/NT/2000/XP
English / United Kingdom
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
HTTP
UPnP, FCC
Status Indicators
Port status, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL Lite, ADSL
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.992.1 (G.DMT) Annex A
WAN: 1 x ADSL - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
External power adapter
Vertical stand
1 x network cable , 1 x phone cable
Software Included
Drivers & Utilities
2.8 cm
11.9 cm
17.5 cm
300 g
0 - 90%
Customer reviews
Write a review for the NETGEAR DG834 BT ADSL Firewall Modem/Router here!
Martin
Reviewed by . Review Posted 23/01/2004
Just installed yesterday. Took 10 mins to install. Router auto connected to BT broadband with only the userid and password. PC's connected to internet with no problems. Very impressed. Ordered this on Tuesday arrived at my door the next day exellent service from DABS.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent! Excellent! and Excellent!
Reviewed by Anonymous Review Posted 22/07/2005
BT 2mb - Dell Laptop + Toshiba Laptop + HP printer + Hp Scanner + HP Ipaq.
1. Dabs service was first class: ordered @ 5pm - received Next day!
2. Couldn't get it to work at first - Spoke to Technical support - answered call immediately - no waiting - talked me thru - now working perfectly. Tech support were excellent and operate 24 hours.
Haven't tried it with Printer & scanner yet - but everything else is great.
*Must buy
  • Overall 5*
  • Ease of use 4*
DG834 ADSL Router - Fantastic
Reviewed by J. Review Posted 25/01/2006
Just purchased this ADSL modem from Dabs (ordered at weekend, arrived following Tuesday...excellent service as usual from Dabs). It must be as a result of the updated firmware the modem has, but it was an absolute doddle to set up, taking about 5 mins to have up and running perfectly.I put my computer together myself and this was by far the easiest bit of kit to get up and running. The DG834 is far superior in every respect to my previous old BT Voyager modem. My ping times to game servers are far less and more consistent; file download speeds are also increased and again more consistent. The firewall blocks everything that is thrown at it, including 100% from the full test at Gibson Research site. In summary this is excellent value for money, VERY easy to install and functions extremely well.....and yes, I am delighted with it.
  • Overall 5*
  • Ease of use 5*
Read all 41 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
