NETGEAR Arlo Outdoor Security Mount in White
Quicklinx: B67LWS00 Mfr#: VMA1000-10000S
Type: Security Accessory
Compatible With: Alexa
Colours:
Hurry, only 3 left in stock!
£10.45 ex VAT
£12.54 inc VAT
Get the perfect angle for your Arlo security cameras. Easily adjustable mount provides 360 degree swivel and 90 degrees of tilt for the Arlo cameras. It's easy to install and adjust the camera position for indoor, outdoor, wall and ceiling mounting.
  • Safe made simple
    Arlo makes it easy to keep tabs on what's happening. Setup is fast. And with the free Arlo mobile app, all it takes to tune in from wherever you are is a quick tap of the finger.
  • More cameras, more options
    It's so easy to add more cameras that you'll spend more time deciding where to put them than you will setting them up.
  • Live stream
    Use the Arlo app to stream live HD views, or rewind your cloud recordings to see what you missed.
  • Customize your system
    Effortlessly adjust your system to fit your routine, keep watch only when you want it to, and avoid false alarms.
Arlo camera pan/tilt bracket
Camera pan/tilt bracket
Placing / Mounting
Ceiling mountable, wall mountable
Indoor / Outdoor
Indoor, outdoor
Arlo VMK3200, VMK3500, VMS3130, VMS3230, VMS3230C, VMS3330, VMS3430, VMS3530; Go Mobile HD Security Camera; Pro VMS4130, VMS4230, VMS4330, VMS4430, VMS4630; Pro 2 VMC4030P, VMS4230P, VMS4330P, VMS4430P; 2 Smart Security System VMS4630P
Placing / Mounting
Indoor / Outdoor
Indoor, outdoor
Mounting Kit
Included
Tilt adjustment, 360 degree pan rotation
Arlo VMK3200, VMK3500, VMS3130, VMS3230, VMS3230C, VMS3330, VMS3430, VMS3530 , Arlo Go Mobile HD Security Camera , Arlo Pro VMS4130, VMS4230, VMS4330, VMS4430, VMS4630 , Arlo Pro 2 VMC4030P, VMS4230P, VMS4330P, VMS4430P , Arlo Pro 2 Smart Security System VMS4630P
Brand: NETGEAR
Price Range Ex VAT: 0 - 50
