Enjoy fast 3G/4G LTE Internet speed wherever you go with the NETGEAR AC762S AirCard Portable Wireless-N 3G/4G Router. Connect up to 10 of your favourite WiFi devices to the Internet and surf for hours with its ultra-long battery life. It's unlocked and ready to go with your choice of service providers without any software to install. The bigger LCD screen makes it easy to use and keeps you up-to-date with real-time data usage. The NETGEAR AC762S AirCard Portable Wireless-N 3G/4G Router is the perfect companion for travellers, mobile workers, students and for those on holiday.
Enjoy the fastest mobile broadband Internet service available (LTE/Dual-Carrier HSPA+)
Wireless-N speed up to 300Mbps
Automatically connects to 3G+/3G/2G mobile networks when 4G LTE is not available
Share the Internet with up to 10 WiFi enabled devices + 1 tethered via USB
Quick and easy setup - unlocked device with auto-detection of your operator's settings
Surf for hours with ultra-long battery life
Use the available microSD card slot to add storage and share files wirelessly
Larger LCD screen for easier monitoring and use
Accelerate productivity with 4G LTE
Supporting download speeds up to 100 Mbps and upload speeds up to 50 Mbps means data heavy applications such as cloud computing and streaming high-definition video are possible with a noticeably smoother experience.
Connect up to 10 WiFi Devices
Share WiFi with family and friends. With the ability to connect up to 10 WiFi devices, get the convenience of sharing 3G/4G LTE with more people and devices like tablets, game consoles, printers and more.
Interactive LCD
Conveniently monitor your hotspot with real-time information displayed on the LCD screen. It relays the number of connected WiFi devices, battery life, network name, password, data usage, and more. Use the navigation button to scroll to additional screens on your device containing the latest messages, alerts, device information, and firmware status.
AirCard App for iOS and Android
Conveniently manage your mobile hotspot connection and data use from a tablet or a smartphone. Download this complimentary app to your iOS (eg. iPhone, iPad), Android or Kindle device and leave your NETGEAR AC762S AirCard Portable Wireless-N 3G/4G Router where you want - in your bag, in the car, or by the window at home.
Standard Warranty: 2-Years
- Maximum speed varies by operating environment and your operatons network capacity.
** Must be used with an active SIM card which can be purchased from a mobile operator in your country. Data plan fees apply, and are sold directly by the mobile operator.
Accelerated performance
Supporting download speeds up to 100 Mbps and upload speeds up to 50 Mbps means data heavy applications such as cloud computing and streaming high-definition video are possible - and deliver a noticeably smoother experience. -
Fast setup
Press the power button and access the Wi-Fi network name and password displayed on the LCD. There's no software to install, and device settings can be managed easily through a web browser. Once setup is complete, you can also connect devices with the push of a button - the WPS button (Wi-Fi protected setup) on the AirCard 762S can securely connect your Wi-Fi device without needing a keyboard or large screen. -
Easy management
Monitor your hotspot with real-time information displayed on the LCD screen - including the number of connected Wi-Fi devices, battery life, network name, password, data usage, and more. Scroll to additional screens on your device to get the latest messages, alerts, device information, and firmware status.
- NETGEAR AirCard AC762S - mobile hotspot - 4G LTE
- Mobile hotspot
- Form Factor
- External
- Max Transfer Rate
- 50 Mbps
- Mobile Communication Protocol
- GPRS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
- Mobile Band
- LTE 800/1800/2100/2600 / HSPA+ 900/2100
- Networking
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Battery
- 2000 mAh
- 9.75 cm x 5.7 cm x 1.52 cm
- 100 g
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- Display
Modem
- Connectivity Technology
- Wireless
- Max Transfer Rate
- 50 Mbps
- Mobile Band
- Antenna
- Internal
- Antenna Qty
- 1
- Wireless
- Data Link Protocol
- Firewall protection, NAT support, MAC address filtering, DNS proxy, port forwarding, IPv4 support
- Supported Flash Memory Cards
- microSD
- Cables Included
- 1 x USB cable
- Capacity
- 2000 mAh
- 9.75 cm
- 5.7 cm
- 1.52 cm
- 100 g
