NETGEAR AC3000 TRI-BAND DESKTOP EXTENDER
Quicklinx: D5BWWS00 Mfr#: EX8000-100EUS
  • IEEE 802.11n
£144.44 ex VAT
£173.32 inc VAT
This Tri-band WiFi Mesh Extender with patented FastLane3 Technology boosts your WiFi speeds. From your garage to the backyard, eliminate WiFi dead zones and extend WiFi range to hard-to-reach areas of your home.
Smart Roaming intelligently connects your mobile devices to the optimal WiFi for 4K streaming, surfing and more. Now you can enjoy uninterrupted streaming on YouTube or Netflix, even as you move around the house.
Smart Connect up to 50 Devices - Intelligently selects between 3 bands to minimize interference and maximize speed for a houseful of smart wireless devices.
Easy Parental Controls - Control WiFi access and set schedules by device easily with the NETGEAR WiFi App.
  • Enhanced connectivity
    With a total of five ports, including four RJ-45 1000Base-T connectors and one Type-A USB 2.0, the NETGEAR Nighthawk X6S Tri-Band EX8000 offers versatile connectivity options for a wide range of devices, ensuring seamless integration into any home network.
  • Robust security
    Equipped with advanced encryption algorithms including WEP, WPA-PSK, and WPA2-PSK, this Wi-Fi range extender provides a secure and private connection, protecting your network from unauthorized access.
  • High-speed performance
    Featuring FastLane3 technology and tri-band Wi-Fi with a Wi-Fi rating of AC3000, the NETGEAR Nighthawk X6S ensures high-speed Internet access across multiple devices simultaneously, without compromising on bandwidth or performance.
NETGEAR Nighthawk X6S Tri-Band EX8000 - Wi-Fi range extender - Wi-Fi 5
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
17 cm x 9.3 cm x 22.7 cm
860 g
1-year warranty
17 cm
9.3 cm
22.7 cm
860 g
External
Wireless
Line Coding Format
256 QAM
Frequency Band
Wi-Fi Rating
AC3000
Auto-sensing per device, Wi-Fi Protected Setup (WPS), Push ā€˜N’ Connect button, Tri-Band, FastLane3 technology
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac
4 x 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
Limited warranty - 1 year
Type: Wi-Fi range extender
Connectivity: Wireless
Protocol: Fast Ethernet
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Brand: NETGEAR
