Nighthawk X4S AC2200 Tri-band Wi-Fi Range Extender provides speeds up to 2.2 Gbps while high-power internal antennas extend Wi-Fi range in hard-to-reach areas of your home. One Wi-Fi Name with any router uses the same Wi-Fi name as your existing Wi-Fi and provides seamless connectivity across router and extender as you roam throughout the house. Unlike other dual-band extenders, the Dedicated Wi-Fi Link helps establish an exclusive connection to the router that avoids automatic bandwidth reduction of extended Wi-Fi signals. Smart Roaming intelligently connects your mobile devices to the best available Wi-Fi for superior streaming as you move around your house.
Enhanced security
With support for WEP, WPA-PSK, and WPA2-PSK encryption algorithms, the NETGEAR Nighthawk X4S ensures your network remains secure against unauthorized access and threats. -
Advanced connectivity
Featuring MU-MIMO technology and Smart Connect, the NETGEAR Nighthawk X4S delivers an efficient and optimized Wi-Fi connection for multiple devices simultaneously. -
Seamless integration
Compliant with a wide range of IEEE standards including 802.11a, 802.11ac, 802.11b, 802.11g, 802.11k, and 802.11n, this Wi-Fi range extender ensures broad compatibility with existing and future devices. -
Dual-band advantage
With 2.4 GHz and 5 GHz bands, the NETGEAR Nighthawk X4S offers a flexible and high-speed Internet experience, reducing interference and congestion for smoother streaming and gaming. -
Easy setup
The Push āN' Connect button and Wi-Fi Protected Setup (WPS) feature make it simple to secure and extend your Wi-Fi network without complex configurations.
- NETGEAR Nighthawk X4S - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Processor
- 1 x
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands)
- 8.382 cm x 7.62 cm x 16.104 cm
- 304 g
- 8.382 cm
- 7.62 cm
- 16.104 cm
- 304 g
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- 1 x
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 2.2 Gbps
- Line Coding Format
- 256 QAM
- Frequency Band
- Wi-Fi Rating
- AC2200
- Wi-Fi Protected Setup (WPS), Push āNā Connect button, MU-MIMO technology, Tri-Band, Smart Connect, Smart Roaming
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac
- Technical support - 90 days
