Kickstart your Windows PC or laptop and experience fast WiFi technology with the Netgear A6210-100PES USB Wireless Adapter.
Ultimate speed and range
Extreme speed is just a USB port away with the A6210-100PES USB Wireless Adapter. Offering impressive speeds of up to 1200 Mbps with 802.11ac, it's ideal for online gaming, browsing, and you can even stream multiple HD videos.
Dual band technology reduces interference for better connections to more WiFi devices, resulting in fewer annoying signal drop outs and making it ideal for connecting larger homes.
Reliable connections
Connections are fast with high gain antennas for increased range and improved performance, and with USB 3.0 you can connect even faster than USB 2.0. A desktop dock allows for flexible placement for your convenience.
Speed, range and reliability are given a further boost with Beamforming+ technology, which helps lock in your signal.
Backward compatible
You don't need the latest technology to use this wireless adapter - even older Windows based desktops and laptops can benefit from fast internet speeds. The A6210 is backward compatible with USB 2.0 and 802.11 a/b/g/n devices.
Setup is quick and easy with Netgear genie included software and Push `N' Connect feature which lets you simply press the button to securely connect and you're ready to go.
Perfect for larger houses, you can enjoy faster online gaming, streaming and browsing with the Netgear A6210-100PES USB Wireless Adapter.
Enhanced connectivity
With dual-band support, the NETGEAR A6210 network adapter allows users to access both 2.4 GHz and 5 GHz Wi-Fi bands, ensuring a more stable and faster Internet connection for various online activities. -
Effortless setup
Featuring a Push ‘N' Connect button alongside Wi-Fi Protected Setup (WPS), this device offers a hassle-free installation process, enabling quick and secure connection to wireless networks without the need for complex configurations. -
High speed
Leveraging the SuperSpeed USB 3.0 interface, the NETGEAR A6210 delivers high data transfer rates, making it suitable for streaming HD video, online gaming, and other bandwidth-intensive tasks.
- NETGEAR A6210 - network adapter - USB 3.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- 9.3 cm x 3.14 cm x 1.445 cm
- 28 g
- Data Link Protocol
- Wi-Fi 5
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Specific Absorption Rate (SAR)
- 1.96 W/kg
- 1-year warranty
- Network adapter
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- WPS, Push ‘N’ Connect button
- Cables Included
- 1 x USB cable (external)
- 1.96 W/kg
- Software Included
- NETGEAR Genie
- 9.3 cm
- 3.14 cm
- 1.445 cm
- 28 g
- Limited warranty - 1 year
