NETGEAR AC WiFi Business Access Point with Insight app for easy managment
Quicklinx: D578WS00 Mfr#: WAC510-10000S
  • IEEE 802.11n
The NETGEAR AC Wi-Fi Business Access Point WAC510 delivers high performance with high client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC510 is managed by NETGEAR Insight app, for a more intuitive and innovative support, with no need for extra management hardware. The WAC510 features Multi-User MIMO (MU-MIMO) to achieve aggregate speeds up to 1.2 Gbps, option to configure as Router or Access Point modes, and comes with two Ethernet ports, including a Power-over-Ethernet (PoE) 1Gb port.
  • Efficient connectivity
    With support for Ethernet, Fast Ethernet, and Gigabit Ethernet alongside Wi-Fi 5 capabilities, this device ensures high-speed connectivity across both wired and wireless networks. It's designed to keep pace with the demands of modern businesses and tech-savvy homes.
  • Advanced security
    Featuring a comprehensive suite of encryption algorithms including WPA, WPA-PSK, WPA2, and WPA2-PSK, alongside multiple authentication methods like EAP and RADIUS, this router provides robust security measures to protect your network from unauthorized access.
  • Seamless operation
    Boasting a high MTBF of 978,210 hours and operational temperatures ranging from 0°C to 40°C, this device promises reliability and durability in various environments, ensuring continuous operation and minimal downtime.
  • Versatile mounting options
    Designed for flexibility, it can be mounted on the ceiling, wall, or placed on a desktop, making it suitable for a wide range of spaces and applications. The included mounting kit facilitates easy installation in the desired location.
  • Dual-band advantage
    The dual-band functionality with 2.4 GHz and 5 GHz Wi-Fi bands allows for a more reliable connection by minimizing interference and congestion, ensuring smoother online experiences for streaming, gaming, and downloading.
NETGEAR Insight Managed Smart Cloud (WAC510) - wireless router - Wi-Fi 5 - desktop, wall-mountable, ceiling-mountable
Wireless router
Enclosure Type
Desktop, wall-mountable, ceiling-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Maximum number of clients: 200
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 1, SNMP 2c, SSH
VLAN support, auto-uplink (auto MDI/MDI-X), MAC address filtering, WMM support, ACL support, QoS, LLDP support, rogue access point detection, TPC, band steering, guest access, 2x2:2 MU-MIMO technology, WDS bridge PtP mode, WDS bridge PtMP mode
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
19.732 cm x 19.732 cm x 3.7 cm
555.5 g
Worldwide (excluding United States and Canada)
Wireless router
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Bonjour
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
Secure Shell (SSH), RADIUS, Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
Wi-Fi Rating
AC1300
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2, EN 60950
Status Indicators
Power, LAN, link/activity, 2.4/5 GHz
WAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE+) - RJ-45 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
9.3 watt
Wall mounting kit, ceiling mounting kit
Mounting Kit
Included
MTBF
978,210 hours
19.732 cm
19.732 cm
3.7 cm
555.5 g
10 - 90%
