Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
NETGEAR A6150-100PES AC1200 WiFi USB Adapter
Quicklinx: FB5MWS00 Mfr#: A6150-100PES
  • IEEE 802.11n
£30.19 ex VAT
£36.22 inc VAT
The NETGEAR AC1200 WiFi Dual-Band Adapter wirelessly connects your notebook or desktop computer to an 11ac network for applications such as lag-free, HD streams throughout your home, online gaming and a secure and reliable connection to the Internet. It is compatible with next generation WiFi devices and backward compatible with 802.11 a/b/g/n devices. The AC1200 WiFi Adapter delivers speeds up to 300/867Mbps and dual-band WiFi technology reduces interference for better connections to more WiFi devices.
  • Speed
    Speed makes all your devices really go. And anyplace you need speed, with NETGEAR you got it. Extreme download speeds of up to 300/867Mbps. Next-generation 11ac WiFi with dual-band technology provides whole home coverage and everything you need for a fast, fast connected home.
  • WiFi range
    Homes come in all shapes and sizes. The AC1200 WiFi Adapter boosts WiFi connectivity throughout your home for all your Internet-enabled devices.
  • Reliable connexions
    Stay connected - with your devices, your media, and your friends. Dual band WiFi provides two separate WiFi networks - 2.4GHz for legacy devices and 5GHz which is less interference-prone for media streaming.
  • Ease of use
    Instalation is easy with a CD to connect to a wireless network. The nano size of the adapter is excellent for travel, plug-n-forget.
NETGEAR A6150 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
2 cm x 1.4 cm x 0.7 cm
5 g
Wi-Fi 5
Frequency Band
2.4 GHz, 5 GHz
Microsoft Windows 7 / 8 / 10 (32/64 bits), Apple MacOS X 10.9 - 10.13
0.54 W/kg
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Beamforming+, 2x2 MU-MIMO technology
0.54 W/kg
Software Included
Drivers & Utilities
2 cm
1.4 cm
0.7 cm
5 g
Wired / Wireless: Wireless
Protocol: IEEE 802.11a
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Type: Network adapter
Brand: NETGEAR
