NetGear A6100-100PES AC600 WiFi USB Mini Adapter 802.11 ac/n
Quicklinx: B82VWS00 Mfr#: A6100-100PES
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • Wi-Fi CERTIFIED
  • IEEE 802.11n
14 In Stock
£23.43 ex VAT
£28.11 inc VAT
Start Flying with Next Generation WiFi
The world's fastest WiFi technology at your fingertips will enable even older Windows®-based laptops to soar at top speed. Simply plug the mini adapter into a USB slot to surf, stream or game - lag time free. NETGEAR dual band performance with Beamforming+ keeps you connected while improving range and reliability.
It's the latest WiFi standard. 3x faster than older standards and NETGEAR delivers it to your home network.
Beamforming+ Gives You Focus
As your laptops and mobile devices roam around the house, Beamforming+ follows you.
Smart and Reliable
Compatible with any standard WiFi router, this AC600 Dual Band WiFi USB Mini Adapter wirelessly upgrades your Windows®-based notebook computer to AC WiFi speeds. The compact, mini designed adapter is perfect for added mobility and allows you to experience lag-free, HD streams throughout your home, online gaming and a secure and reliable connection to the Internet. With up to 150/433Mbps speed, dual band and Beamforming+, the A6100 avoids interference ensuring top WiFi speeds and reliable connections. Easy setup with the NETGEAR® genie® gets you up and running fast, while Push `N' Connect gives you a secured connection at the push of a button.
Extended range and performance with 802.11ac (150 Mbps/433 Mbps)
Innovative mini-design
Perfect for online gaming and video streaming
Beamforming+--Faster, more reliable connections
Works with any standard WiFi Router or Modem Router/Gateway like Belkin®, Linksys®, D-Link®, NETGEAR®, & others
  • Speed
    Speed makes all your devices really go. And anyplace you need speed, with NETGEAR you got it. Extreme download speeds of up to 150/433 Mbps. Next generation 11 ac Wi-Fi with dual band technology provides whole home coverage and everything you need for a fast, fast connected home.
  • Wi-Fi rang
    Homes come in all shapes and sizes. The NETGEAR A6100 Wi-Fi USB mini adapter boosts Wi-Fi connectivity throughout your home for all your Internet-enabled devices.
  • Reliable connections
    Stay connected - with your devices, your media, and your friends. Dual band Wi-Fi provides two separate Wi-Fi networks - 2.4 GHz for legacy devices and 5 GHz which is less interference-prone for media streaming.
NETGEAR A6100 WiFi USB Mini Adapter - network adapter - USB
Network adapter
External
Interface (Bus) Type
USB
3.61 cm x 1.84 cm x 0.81 cm
8 g
Wi-Fi 5
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
0.99 W/kg
Network adapter
External
USB
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
WPS, Push ‘N’ Connect button
0.99 W/kg
Software Included
NETGEAR Genie
3.61 cm
1.84 cm
0.81 cm
8 g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: NETGEAR
