NETGEAR 8PT GIGE8-port unmanaged with 2PT uplinks
Quicklinx: D5BZWS00 Mfr#: GS110MX-100UKS
Type: 10 Gigabit Ethernet
Ports: 8
Managed: No
POE: No
£145.20 ex VAT
£174.24 inc VAT
NETGEAR GS110MX Managed Switch. Perfect for a desktop and it's rack-mountable or even wall-mountable.
  • Robust performance
    With a switching capacity of 56 Gbps, the NETGEAR GS110MX ensures efficient handling of network traffic, maintaining optimal performance even in high-demand environments.
  • Versatile connectivity
    Equipped with 8 ports of 1000Base-T and 2 uplink ports supporting speeds up to 10G, this switch offers a wide range of connection options for various networking needs, from standard to high-speed requirements.
  • Advanced networking features
    Features such as 128KB packet buffer, DiffServ Code Point (DSCP) support, Link Aggregation, and port mirroring enhance network management and efficiency, providing tools for sophisticated traffic prioritization and monitoring.
  • Flexible installation options
    The NETGEAR GS110MX can be easily integrated into any setup with its desktop, rack-mountable, and wall-mountable form factors, accompanied by a rack mounting kit for seamless installation.
  • Energy-efficient design
    Incorporating the IEEE 802.3az (Energy Efficient Ethernet) standard, this switch optimizes power usage, reducing operational costs without compromising performance.
NETGEAR GS110MX - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
8 x 1000Base-T + 2 x 100/1000/2.5G/5G/10G (uplink)
Performance
Fabric throughput: 56 Gbps , Latency (10 Gbps): < 3 µs , Latency (1000 Mbps): < 4 µs , Latency (100 Mbps): < 7 µs , Packet forwarding rate: 41.664 Mfps
MAC address entries: 16000 , Priority queues: 8
Jumbo Frame Support
10240 bytes
Trunking, DoS attack prevention, port mirroring, Quality of Service (QoS), Jumbo Frames support, fanless, 128KB packet buffer, Energy Efficient Ethernet, loop prevention, DiffServ Code Point (DSCP) support, cable test, Link Aggregation, Voice VLAN
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
23.6 cm x 10.2 cm x 2.7 cm
740 g
United Kingdom
ProSAFE lifetime warranty
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
10240 bytes
Status Indicators
Power, link/activity/speed
External power adapter
Installed Qty
1
13.2 Watt
Rubber feet, wall mounting kit
Rack Mounting Kit
Included
CB, UL 60950-1, KC, EAC, CNS 13438, EN 61000-3-3:2013, EN 61000-3-2:2014, FCC CFR47 Part 15 B Class B, EN 55024:2010+A1:2015, EN 55032:2012+AC:2013 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, CISPR 32:2012, CAN/CSA-C22.2 No. 60960-1-07, ICES-003:2016 issue 6 Class B, AS/NZS CISPR 32:2013 Class B, EN 55032:2015+AC:2016, CISPR 32:2015+COR1:2016, VCCI-CISPR 32:2016 Class B, AS/NZS CISPR32:2015 Class B, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
United Kingdom
23.6 cm
10.2 cm
2.7 cm
740 g
Limited warranty - replacement - lifetime , Technical support - on-site
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
