NETGEAR 8Pt 10G/Multigigabit Unmanaged Switch
Quicklinx: D9Q7WS00 Mfr#: XS508M-100EUS
Type: 10 Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: No
POE: No
Select:
£424.31 ex VAT
£509.17 inc VAT
The XS508M come with Copper Ethernet ports that provide either Fast Ethernet, 1-Gigabit, 2.5-Gigabit, 5-Gigabit or 10-Gigabit connectivity, as well as 1 SFP+ Fiber port with 1-Gigabit or 10-Gigabit connectivity. Each port automatically detects which speed is needed by the connected device and provides the adequate speed. Also, the new NETGEAR Multi-speed switch ports can be connected with regular Cat5E Ethernet cables, without the need to upgrade to Cat6 wiring, therefore reducing wiring costs and hassle.
  • Robust performance
    With a bandwidth capacity of 160 Gbps, the NETGEAR XS508M switch ensures efficient handling of large data across its network, making it ideal for businesses with high data demands.
  • Versatile connectivity
    Equipped with 7 RJ-45 10GBase-T ports and an additional RJ-45/SFP+ 10Gbit LAN port, this switch offers flexible connection options to meet various networking requirements.
  • Durable design
    The metal housing and a built-in fan contribute to the NETGEAR XS508M's durability and reliability, ensuring it operates efficiently even in demanding environments.
  • Energy efficient
    Features like Energy-Efficient Ethernet (EEE) and a power consumption of only 39 W make the NETGEAR XS508M an eco-friendly choice for your networking needs.
  • Advanced networking features
    Support for Quality of Service (QoS), Class of Service (CoS), and Weighted Round Robin (WRR) allows for prioritization of traffic, ensuring critical data is delivered swiftly and reliably.
NETGEAR XS508M - switch - 8 ports - unmanaged - rack-mountable
Switch - 8 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
7 x 10 Gigabit Ethernet + 1 x 10 Gigabit Ethernet / 10 Gigabit Ethernet SFP+
Performance
Bandwidth: 160 Gbps
Priority queues: 8
MAC Address Table Size
2K entries
Jumbo Frame Support
9KB
DiffServ support, store and forward, QoS, 128KB packet buffer, CoS, metal housing, 1 fan, EEE, WRR
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.32 cm
1.49 kg
United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Bandwidth: 160 Gbps
Priority queues: 8
2K entries
Jumbo Frame Support
9KB
Status Indicators
Power, fan, link/activity/speed
7 x 10GBase-T RJ-45 , 1 x 10Gbit LAN RJ-45/SFP+
Internal power supply
39 watt
Rack Mounting Kit
Included
MTBF
1145157 hours
Plug and Play, VCCI, BSMI, ICES-003, EN55024, AS/NZS 60950-1, UL 60950-1, KCC, KC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, AS/NZS CISPR 32 Class B, CNS 14336-1, VCCI V-4/2012.04, VCCI V-3/2015.04 Class B, ANSI C63.4-2014, CISPR 32, EN 55032, EN 55032:2012+AC:2013 Class B, ICES-003:2016 issue 6 Class B, EN 61000-3-2:2014 Class B, EN 6100-3-3:2013, sDoC, CB 60950-1, LVD 60950-1
32.8 cm
16.9 cm
4.32 cm
1.49 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
50 °C
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
