Today's networks have increasing numbers of devices, attached to them, both wired and wireless. As wired devices proliferate, it can be difficult to easily and neatly place networked ports, where you want them. NETGEAR ProSAfe Click switches address this issue with an innovative and thoughtful hardware design, including the flexible Virtually Anywhere Click mounting system. NETGEAR ProSafe web managed Gigabit Ethernet Click switches are uniquely designed with a bracket mounting system for easy installation. Their slim design and internal power supplies enable you to organize wires, secure cables, eliminate bulky power adapters, and improve the overall appearance of wiring closets, training facilities, lab benches, conference rooms, and even home entertainment centers, that require multiple connected devices.
The innovative Virtually Anywhere mounting system gives you the flexibility to place the ProSafe Click switches in locations, where other switches cannot go. Whether it's directly on a wall, strapped to a pole, under the meeting table in a conference room or in a server closet, vertical or horizontal, flat or perpendicular, the Click switch's unique mounting system allow you to control exactly how and where your ports and cables are deployed. -
Easy cable management
Multi-directional power cable can be routed outwards or to suit any mounting needs. Ethernet cables can be strapped to the bracket or mounting surface, using the provided retaining strap.
 - NETGEAR Click GSS108EPP - switch - 8 ports - Managed
 - Switch - 8 ports - Managed
- Subtype
 - Gigabit Ethernet
- Ports
 - 4 x 10/100/1000 (PoE+) + 4 x 10/100/1000
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 47 W
- Performance
 - Bandwidth: 16 Gbps , Latency (10 Mbps): < 77 µs , Latency (100 Mbps): < 8.9 µs , Latency (1000Base-T): < 2.6 µs , Forwarding performance (64-byte packet size): 11.9 Mpps
- Capacity
 - Virtual interfaces (VLANs): 64 , Priority queues: 4 , Layer 2 multicast groups: 128
- MAC Address Table Size
 - 4K entries
- Jumbo Frame Support
 - 9000 bytes
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
 - HTTP
 - Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, full duplex mode, firmware upgradable, vertical mounting, TFTP support, QoS, horizontal mounting, Jumbo Frames support, fanless, Energy Efficient Ethernet, loop prevention, link aggregation trunking, 192KB packet buffer, Multicast filtering function, CoS, DoS, metal housing, DSCP support, cable test, Virtually Anywhere Mounting, Voice VLAN
 - IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3at, IEEE 802.3az
- Power
 - AC 120/230 V (50 - 60 Hz) 1.4 A
 - 30.5 cm x 6.5 cm x 3.5 cm
 - 3.2 kg
- Localisation
 - United Kingdom, Europe
 - ProSAFE lifetime warranty
- Enclosure Type
 - Desktop, wall-mountable, pole-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 47 W
- Performance
- Capacity
 - 4K entries
 - 9000 bytes
- Routing Protocol
 - HTTP
- Status Indicators
 - Port transmission speed, power, PoE, link/activity
 - 4 x 1000Base-T RJ-45 PoE+ - 124 W , 4 x 1000Base-T RJ-45
- Power Device
 - Internal power supply
- Voltage Required
- Electric Current Required
 - 1.4 A
 - 5 Watt
- Included Accessories
 - Cable retaining/pole mounting straps
- MTBF
 - 1,494,913 hours
 - CB, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07, KC, EAC, CNS 13438, EN 55024:2010, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, FCC CFR47 Part 15 B Class B, EN 6100-3-3, EN55022:2010 + AC:2011 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04 Class A, ANSI C63.4-2014, ICES-003 issue 6 Class B, AS/NZS CISPR22:2009+A1 Class B, AS/NZS 60950-1:2015, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Software Included
 - ProSAFE Plus Configuration Utility
 - 30.5 cm
 - 6.5 cm
 - 3.5 cm
 - 3.2 kg
 - Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting
 - 0 °C
 - 40 °C
 - 90% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 95% (non-condensing)
