NETGEAR 8 x 1G/10GBASE-X SFP+ Port Card For M4300-96X
Quicklinx: DF3SWS00 Mfr#: APM408F-10000S
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, 10 Gigabit Ethernet
Form Factor: Plug-in module
Type: Expansion module
£391.94 ex VAT
£470.32 inc VAT
Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
  • High-speed connectivity
    Equipped with 8 SFP+ ports, this expansion module delivers a high-speed wired connectivity option, supporting data transfer rates of up to 10 Gbps. Ideal for businesses requiring fast and reliable network connections for handling large data volumes efficiently.
  • Versatile network integration
    Featuring support for both Ethernet 1000Base-X and Ethernet 10GBase-X cabling types, the NETGEAR APM408F offers flexible integration options into existing network infrastructures, ensuring compatibility with a wide range of networking equipment.
NETGEAR APM408F - expansion module - 10GBase-X x 8
Expansion module
Plug-in module
Ports
10GBase-X x 8
300 g
Worldwide
Cabling Type
Ethernet 1000Base-X, Ethernet 10GBase-X
1GbE, 10GbE
Data Transfer Rate
10 Gbps
Expansion module
Plug-in module
Worldwide
Ports
10GBase-X x 8
Wired
Cabling Type
Data Transfer Rate
10 Gbps
8 x 10GBase-X - SFP+ - female
300 g
Protocol: 10 Gigabit Ethernet
Brand: NETGEAR
