Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
Versatile connectivity
With an array of RJ-45 connectors, this NETGEAR APM408C expansion module offers versatile connectivity options, supporting 1/2.5/5/10 GBase-T interfaces. It's designed to meet the demands of diverse network environments, ensuring compatibility with various Ethernet standards. -
High-speed data transfer
Achieve up to 10 Gbps data transfer rates with the NETGEAR APM408C. This expansion module is engineered for high-performance networking, facilitating swift data link protocols including 10 Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet, Fast Ethernet, and Gigabit Ethernet. -
Seamless integration
The plug-in module form factor of the NETGEAR APM408C ensures seamless integration into existing network setups. Its design promotes easy installation, making it a straightforward solution for expanding your network's capabilities.
 - NETGEAR APM408C - expansion module - 1/2.5/5/10GBase-T x 8
 - Expansion module
- Form Factor
 - Plug-in module
- Ports
 - 370 g
- Localisation
 - Worldwide
- Cabling Type
 - Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
- Data Link Protocol
 - 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
- Data Transfer Rate
 - 10 Gbps
 - Expansion module
- Form Factor
 - Plug-in module
- Localisation
 - Worldwide
- Ports
- Connectivity Technology
 - Wired
- Cabling Type
 - Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
 - 10 Gbps
 - 8 x 1/2.5/5/10GBase-T - RJ-45 - female
 - 370 g
